Parking assist fault
mattandrew Jan 28, 2008
  1. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    Yesterday my A3 8P parking assist started playing up, When you put it un reverse you get a long beep then nothing. Manual states if you get this there is a fault.
    Just Vagcom check and get the following.
    Monday,28,January,2008,21:05:42:12592
    VAG-COM Version: Release 704.1
    Address 76: Park Assist
    Control Module Part Number: 8P0 919 283
    Component and/or Version: Parkhilfe 4-Kan H06 0020
    Software Coding: 0001003
    Work Shop Code: WSC 06435
    1 Fault Found:
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 138
    Mileage: 103555 km
    Time Indication: 0
    Date: 2008.01.28
    Time: 20:59:25
    I can see it is a problem with the rear mid left, does this mean a new sensor is need?
    Anyone experienced this
    Thanks in advance Matt
  2. NIGEL
    NIGEL New Member
    HI pop the sensors out and swap them over to see that the rear mid left sensor is infact the problem. It could be wiring or bad connection.
    Hope this helps.
