PANIC!!!!! Heeeeelp
wellhouse0 Feb 14, 2011
  1. wellhouse0
    wellhouse0 Member
    82
    got someone coming to buy my A4 B5 Avante and i'm stripping all the ICE i've put in so need to replace original Audi sub etc. Put sub back in and have reconnected the red multi block plug back onto the sub but there is a smaller flattish black plug with 2 wires on it that come off the same bit of loom that goes to the sub, does anyone know what it connects to? aaaagh
  2. wellhouse0
    wellhouse0 Member
    82
    no one? ideas?
  3. wellhouse0
    wellhouse0 Member
    82
    pictures added
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    I can't 100% say what it is or where it goes but it looks like its a power lead for something.
    Amp?
  5. wellhouse0
    wellhouse0 Member
    82
    does the genuine audi auto changer have 2 plugs? one multi pin round plug and another one that takes the plug i've photod? could be the autochanger power lead if so
  6. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    No the power on all Audi changers in within the bus cable.
    That red connector looks identical to the A3 sub plug, which has all the necessary power/earth/feeds within it, so wouldn't have thought the black was anything to do with the sub amp. Is the sub/rear amp not working? Check you have perm live and switched live going to it:
  7. wellhouse0
    wellhouse0 Member
    82
    cheers andy, everything appears to be working i'm just left with this one last plug. Could it be for the audi autochanger i haven't got? there is the round autochanger din in the right place, maybe this is for an autochanger if you want to fit one
  8. wellhouse0
    wellhouse0 Member
    82
    panic over, black plug was for auxilliary 12v on rear quarter panel cover. didn't spot it until i went to refit it having given up! However i now can't find the rear carpetted cover that hides the autochanger hole!!!! aaaagh someone trying to test my patience. Has anyone got one they don't want?
  9. wellhouse0
    wellhouse0 Member
    82
    thanks all sorted now, cheers
