painting interior trim?
olds_kool Jan 12, 2011
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    hi folks
    after years of searching for double din centre console conversion parts ive come across some at a reasonable price
    only trouble is its in light grey and my interior is dark grey
    has any one had good results in painting this type of plastic, if so what did you use?
    cheers kev
  2. Foxmeister
    Foxmeister Fired Up!
    1,785
    I would use a plastic based primer to achieve durability.
    Like any painting process, its all in the prep mate;
    Firstly, thoroughly clean the part
    Then score/sand it to key the base
    Clean again
    Then apply primer, 2 or more coats dependant on finish(shine, matte etc) leaving 15-20 drying periods between
    Leave part to fully cure/dry, overnight, then wet sand
    Clean again
    Then start applying top coats, leave again to cure overnight
    Wet sand to a smooth finish
    Then apply laquer coats, wet sand if needed.
  3. Yappy
    Yappy A4 b6 TDI V6 Quattro Sport
    150
    You can buy a sort of bumper textured finish paint from any good paint supplier you will have to get some red scotch brite to key the surface then find the paint colour you like also as foxmeister said get a plastic primer the one I use is clear and is more an adhesion promotor paint this on leave for 5 10 mins an then spray straight on to it with the textured finish paint or just an aerosol ( if you go for just a paint get some primer to give the top coat some depth and follow as above reply ) hope all goes to plan mate
  4. olds_kool
    1,089
    cheers guys,
    came across this and it seems that plastic can be dyed?
    www.vinyldye.co.uk
    think ill give it a go with some matt black and see how it turns out
    thats if i buy the console, going to look at it tommorrow
  5. Rick_RS4
    Rick_RS4 New Member
    25
  6. aragorn
    17,876
    687
    i've used the halfords stuff on a dashboard in a nova before (kinda soft touch vinyl surface) and it worked well
    rasa4 has painted his glovebox iirc
  7. Foxmeister
    1,785
    Halfords gear is actually good quality, paint wise anyway!
    Used it for painting my wheels, and primers etc, aluminuim paint for mirrors also, good quality stuff!!!
