Paino black interior trim
ei2gfb Aug 12, 2013
  1. ei2gfb
    ei2gfb Member
    102
    my car has the piano black gloss interior trim but i notice my gearstick surround and ashtray are just normal matte black plastic, but some of the other cars i test drove had the walnut finish and the aluminium style finish and both had the same effect on gearstick surround and ashtray, should mine have the same gloss black around the gearstick??
  2. alpesh26
    alpesh26 Active Member TeamMisano
    446
    53
    It's meant to be matte black. I don't think Audi ever made the gear surround and ashtrays in piano/gloss black
  3. stuartclarke
    stuartclarke New Member
    10
    Ide be interested to know this too as mine sounds the same as yours, both the gearstick surround and ashtray have started to peel and it would be good to know if there is a surround that could be bought to match the rest of the trims before I go to TPS to order replacements
  4. ei2gfb
    ei2gfb Member
    102
    i was thinking of getting some kind of gloss black vinyl wrap and trying to match as gloss as possible to original
  5. Andie0
    Andie0 Member
    490
    13
    Take off the pieces and match the black with a spray colour then spray it
  6. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Vinyl wrap it in gloss black
  7. stuartclarke
    10
    Might as well give this ago, I planned on replacing them anyway because mine are peeling so if it don't look right ill buy new
  8. Mollygoogle
    Mollygoogle Member
    262
    10
    just wrap it, much quicker and easier
  9. ei2gfb
    ei2gfb Member
    102
  10. pauldazzle
    pauldazzle Well-Known Member
    1,193
    95
    Part number for piano black ash tray cover is 8E0857967S 1LQ
    Gear stick surround is 8E0864261AH1LQ
  11. ei2gfb
    ei2gfb Member
    102
    interesting must keep an eye out in breakers yards, however a quick google brings up ecs listing the parts and the gear surround is $260!!!
  12. pauldazzle
    1,193
    95
    On Vagcat (prices in euros) the ash tray cover is about £30 & the gearstick surround is about £50
  13. ei2gfb
    ei2gfb Member
    102
    ill be in garage in morning getting fuel filter replaced so ill quote the numbers and check it out cheers:thumbsup:
  14. ei2gfb
    ei2gfb Member
    102
    was in local seat garage as nearest audi garage is well over an hours drive away and got them to check part number the gearstick surround is €55 ex vat and part number is 8E0864261A(N) N for manual the H was for auto, the ashtray cover is €26 ex vat and the exeo part number is the same bar an E at the end 8E0857967E, Inc vat works out at €100 i think ill wrap first and if im not happy i can buy the parts
  15. WOLF
    WOLF Well-Known Member
    1,201
    270
    Ive just painted mine to get rid of the matt black that was scratched,make sure you remove all the rubber coating before spraying.
    All fitted with new gearknob,chuffed with it.
  16. ei2gfb
    ei2gfb Member
    102
    any pics what spray paint, primer etc did you use
  17. WOLF
    1,201
    270
    I'll get some tomorrow.
    First remove the ashtray cover and surround then seperate the 2 alli strips on the ashtray and the strip that holds them.
    I used wet and dry to remove the rubberised coating followed by 4 coats of grey primer de nibbing between coats,5 coats of gloss black de nibbing again.I applied 6 coats of laquer and de nibbed as neccesary.All done with cans.
    A massive improvement from the standard finish imo.
    ei2gfb likes this.
  18. WOLF
    1,201
    270
    Here ya go,as promised.I'll remove this at the weekend and buff it once paint is hard...
    Also in the picture is my new gearknob,audi a3 with carbon top i did as reverse was different on the a3 .
    Sorted.
    ei2gfb likes this.
  19. ei2gfb
    ei2gfb Member
    102
    thats impressive really smartens up that area, will definately be giving this a go
  20. pauldazzle
    1,193
    95
    Yeah like it. With a polish up it should look even better:thumbsup:
