Pads and discs all round
jamie226bhp Apr 30, 2010
  1. jamie226bhp
    jamie226bhp Member
    468
    Need to do the brakes all round on my 1.8tqs any recomendations on pads and discs to buy would like to get some grooved discs and some hal decent pads bit budget is tight p
    only about £300
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    I could be wrong but i think your as well just getting normal good quality disks. I just got a price today for rear disks and pads for my quattro and it was about £60 with forrodo pads.
  3. aragorn
    18,174
    770
    I wouldnt bother with fancy disks. Its just a lump of steel at the end of the day. Save your money and spend it elsewhere.
    Just buy some decent quality disks from Mintex or Ferodo or similar, and then pads of your choice.
  4. jamie226bhp
    jamie226bhp Member
    468
    So just pads n discs from gsf and change the fluid will be ok
  5. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    You could also consider upgrading the lines to goodridge braided ones. It actually makes a hell of a difference in pedal feel. 50 bucks for all corners.Well worth it whilst your in the brake neck of the woods.
  6. jamie226bhp
    jamie226bhp Member
    468
    Thanks lads GSF for the brakes and new lines then
  7. Matt82
    Matt82 Active Member
    2,365
    or eurocarparts. they do ATE and pagid bits there
  8. jamie226bhp
    jamie226bhp Member
    468
    where does them for £50 for all round as they seem to want £100 plus for a 2000 1.8t quattro
  9. SteVR
    SteVR Member
    standard quality discs and ferrodo ds2500 pads would be my choice.
  10. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
    Pagid disc's & pads would be my choice, just done front & rears and was very impressed with the improvement.
  11. jamie226bhp
    jamie226bhp Member
    468
    how much did that cost
  12. B5NUT
    3,705
    643
    It was around 150 mark, got the lot from eurocarparts, do a on-line quote as delivery is free. However they use there own van's so you must be in to receive delivery.
  13. jamie226bhp
    jamie226bhp Member
    468
    i'll see if gsf do pagid as my mate gets discount there
  14. phoenixv6quattro
    1,396
  15. aragorn
    18,174
    770
    I'm pretty sure all quattros run the same lines, front and rear, including the S4!
    I found 2 of the goodrich hoses i recently fitted to craigs S4 to be slightly too long, the ones that go between the subframe and wishbone, were about 10mm longer than the OE hoses we removed, meaning they kinked a little too much for my liking.
  16. jamie226bhp
    jamie226bhp Member
    468
    did wonder why would change as they normally keep as much the same as possible
