Paddle Extensions?
Liam Miller Jan 15, 2017
  1. phobos512
    phobos512 Active Member TFSI Owners Group Team Vegas Yellow Audi S3 saloon DSG
    109
    111
    43
    Installed. Piece of cake.
    Sent from my iPhone using Tapatalk Pro
    Mark_86 likes this.
  2. Mark_86
    Mark_86 Well-Known Member Team Daytona Audi S3 quattro Black Edition DSG
    1,191
    1,584
    Look awesome. So, how easy was it? Good job mate!
    phobos512 likes this.
  3. SeoTFSI
    SeoTFSI Active Member Team Vegas Yellow Audi S3
    111
    218
    43
    WoW!! Wonderful! :hubbahubba:
    I can't wait anymore for mine!!!
  4. Daz4311
    Daz4311 Well-Known Member
    545
    366
    Need a set of these now.
  5. Nath.S4
    Nath.S4 Active Member
    142
    136
    43
    These look great. Couple questions...
    Do you think they will fit the s4 paddles ?
    And the little grub screws do they screw in and mark the original paddles ?
  6. SteveMcB
    SteveMcB Well-Known Member Team Sepang Audi Cabriolet Owner Group SQ5 owners group
    778
    372
    Nice, fancy these on the SQ5
    paul wev likes this.
  7. phobos512
    109
    111
    43
    First, no idea if they would fit other vehicles than the S3 (as demonstrated here) and the latest A4 (as listed in the eBay ad). Sorry.
    So for the install here's how I did it:
    For each set screw I placed the set screw on the included hex (Allen) wrench. Then, I applied a drop of Loctite 242 (medium strength removable threadlocker) and let it penetrate, then wiped off the excess. For the inside screws (those toward the hub/airbag) I applied these on my workbench, screwing them in till flush. Then I popped the paddle on the paddle and applied the remaining screws. Due to the shape of the wheel and the length of the included wrench I could only get a half turn so I would turn the wrench 180 degrees, remove it, reset and continue. The top screws were easier than the bottom screws due to the shape of the wheel. On doing the passenger side I couldn't as readily get the paddle extension to "pop" into place so I loosened the top inside set screw slightly since it is accessible from the top of the wheel. At the end of tightening each screw I wiped off any excess Loctite with a shop towel I had just for this purpose, and I wore latex gloves so as not to get Loctite on my fingers and accidentally spread it to the interior of the car.
    I could see marring the paddles if you're not careful - they press against the corners of the paddle so since they're just black plastic marring would look like a very small indentation. I don't expect it would be too visible if it did happen. However by design the screws are going to compress the paddle extension against the paddle so depending on how soft the plastic is it may or may not mar.
    They provided in my kit two extra set screws, which is handy as they're so small and I have large hands. I didn't end up needing them though. In all with my meticulous prep it took about fifteen minutes to install. I could probably do it again in five.
    azibux1 and paul wev like this.
  8. SeoTFSI
    111
    218
    43
    Here mine.
    I hoped in a better grip but i feel anyway better than the standard micro-paddles
    RickyB, MattSedg and samo26 like this.
  9. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,392
    2,803
    Finally received and fitted mine. Very easy :)
    BodegaBay and S15THM like this.
  10. S15THM
    S15THM Daytona S3 Saloon Team Daytona saloon s tronic S3 Saloon DSG
    728
    859
    93
    I like them, but they're slightly too big for me. There's really not a broad choice of variety for a car of it's kind sadly.
  11. seanbeckerleg
    seanbeckerleg Active Member
    155
    182
    43
    Can anybody tell me if the the FL paddles are the same as the PFL? I've seen a few I like but they don't say wether they'd fit a 2017 s3.... just 8v platform.
  12. DJAlix
    3,392
    2,803
    Thats what this thread is about. In short PFL paddles are different to the FL ones, which are now the same shape as the TTmk3 and new A4. The ones I pictured above were advertised as being for the A4.
    BodegaBay likes this.
  13. SeoTFSI
    111
    218
    43
    No, they aren't the same.
  14. seanbeckerleg
    155
    182
    43
    Ok mate, cheers!
    So are these the only one available at the moment? Where can I get a set?
  15. paul wev
    paul wev New Member
    27
    I haven't seen any for my 2013 SQ5? They are slightly bigger with a silver edge around the paddles. Could anyone help please?
    SQ5
  16. DJAlix
    3,392
    2,803
  17. JunkStory
    JunkStory Member
    47
    27
    my sincere advice is do not screw around with those little tapping screws. They will inevitably damage the original paddles by digging holes in them. I really regret doing that to mine, and now I just use some good double sided tape and cut them into shape. But the damage is already done.
    Nath.S4 likes this.
  18. Netster
    Netster New Member
    Looks like they dont follow contours of the steering wheel unfortunately, how are you liking them?
  19. phobos512
    109
    111
    43
    They are perfectly flat from the side so no they don't follow the profile of the wheel; however from the front I'd say they follow the curve of the wheel just fine (and since that's what you see that's what matters). Still like em just fine, no regrets.
  20. Netster
    Netster New Member
    Thanks, was wondering if it effects the reach. Debating on these my self.
  21. S15THM
    728
    859
    93
    I want something simple like the RS ones :(
    Mac135 likes this.
  22. Ryman
    Ryman New Member Team Panther Audi S3 s tronic
    23
    22
    I agree, assume there’s nothing on the market since this thread?
  23. Bells
    Bells Active Member Audi S3 Black Edition s tronic Team Ara Blue
    121
    131
    43
    Do the facelift RS3 (standard) metal tipped paddles not plug and play?
  24. Ryman
    23
    22
    I don’t know, I would imagine they would require the wheel to be taken apart?
  25. Bells
    121
    131
    43
    Not sure to be honest, I don’t know how the current ones are attached, whether it is by clips or not etc
  26. Netster
    Netster New Member
    Yup. Airbag comes out, then the bezel, followed by finger tip control units. Once all that's out you'll have access to the paddle shifter screw.
    Here's the frustrating part, bezel has male pins that insert into rubber foam. Maybe this is unique to my experience but, since being dissembled, this bezel refuses to sit flush against the steering wheel like it did before.
    Last year I tried three sets of paddles during my search- Ebay ones pictured above, OEM RS, and RelakMoto.
    OEM RS's were an improvement over stock but still a tad small. Plus wish i hadnt disassembled the wheel.
    Ebay extensions design is flawed. As they extend out they move further away from your reach due to their non curved design. This can also be observed by looking at their side profile. This completely defeats their purpose as i had to extend my fingers and re-position my hand to shift with them.
    RelakMoto's are the ones i stuck with. They are curved, thereby allowing extensions to follow a consistent spacing with the wheel. Also the rubber coating is a nice touch, they feel silky smooth and give off an oem look.
    If anyone's interested in the OEM RS shifters i still have my set laying around. Will be posting them in classifieds soon.
  27. KyleS3
    KyleS3 New Member
  28. larbel
    larbel Well-Known Member Team Sepang Audi S3 saloon
    553
    555
    93
    I’m using RS paddles and the bezel is somewhat flexible and there’re catches all around, you’ll need to make sure the catches are in place and the inserts are in the slots. It will sit flush, I took it apart (FL n PFL) multiple times without issues.
