P9571 fault code help
Djwoody Jan 10, 2013
  1. Djwoody
    Djwoody Member
    480
    21
    Hi.
    I have a code that is coming up:
    009571/P2563 - Turbocharger_Boost_Control_Position_Sensor_Circuit
    Once I have been travelling at motorway speeds for over about 15 minutes, if I then pull over, put the car in neutral and leave it ticking over. The MIL starts flashing after around 5 seconds.
    On short journeys around town the light doesn't flash.
    Can anyone help?
    I have already had the actuator, pressure sensor and N75 valve replaced.
    Chris
    2008 A3 2.0 TDi 170
  2. Djwoody
    Djwoody Member
    480
    21
    Hi.
    Can anyone help?
    Chris
    2008 A3 2.0 TDi 170
  3. NHN
    29,333
    1,717
    Please keep it in one thread, not 2, as makes a mess of the problem, so where would you like to have the thread to continue & the other will be removed.
  4. Djwoody
    Djwoody Member
    480
    21
    i didn't realise this section existed until after I posted in the A3 section and couldn't remove it.
    Please remove it from the A3 section
  5. S3AMK20VT
    S3AMK20VT Member
    170
    Possible Causes
    • G581 Faulty
    • Wiring and/or connections faulty
    • ECM faulty
    [h=4]Possible Solutions[/h]
    • Check fuses
    • Check wiring and connections
    • Ohm test G581, see factory repair manual
  6. NHN
    29,333
    1,717
    170 has an electrical actuator afaik, check wiring to it.
  7. Djwoody
    Djwoody Member
    480
    21
    Yeah think i'll check the wiring.
    As i've had those new parts fitted everything should be working ok.
    I've been told that the adjustment on the actuator is quick tricky to get spot on, i might have to go to a specialist I think. Dread to think what Audi would charge.
    What does it mean by ECM faulty?
  8. NHN
    29,333
    1,717
    electronic control module.
