P2100 Fault on 2.5 Tdi B6 A4 convertible
tibyy17 Jul 17, 2012
  1. tibyy17
    tibyy17 New Member
    Hello guys,
    On Sunday my engine management light came on after started the engine. I checked the fault code: 2100 - "
    Throttle Actuator Control Motor Circuit: Open". I cleared the fault, and its gone. Happy days, till the next cold start when the light came back on. So I decided to remove and clean the throttle body. Its was clean and the flap was moving as it should (I just replaced the throttle body 8 months ago).
    I did check all cables and wires, they are all good and the car drives normal. Any ideas what to do next? All help appreciated.
  2. tibyy17
    tibyy17 New Member
    I did some research and apparently on other models its a blown fuse (F8 or 24), lose air hose or lose connector wire or a faulty throttle motor. I was spending my whole afternoon under the bonnet just to look for these things, and checked every fuse in the driver cabin (next to the steering wheel on the side). I got a few questions:
    1: Is there another fuse box in the A4 B6 or just the one I checked?
    2: How can I check if the Throttle Actuator Motor is working?
    3: Anybody have heard of the same fault code on 2.5 Tdi?
  3. adamss24
    adamss24 Well-Known Member
    4,578
    402
    The plastic gubbins inside the throttle body are damaged hence the flap not operating correctly, they are about £300 from local audi dealer...
  4. tibyy17
    tibyy17 New Member
    Thank you Adam! I will buy a new throttle body and give it a go...
