P1719 error - My experience
viceroy Feb 12, 2014
  1. viceroy
    viceroy Active Member
    284
    76
    Hey guys,
    I just wanted to share my experience with this error.
    There is not much on the web related to Audi and this error, but one thread was right here on this forum.
    LINK
    Now my experience was different and my code was slightly different too.
    The error I got was 3 days after remapping the car
    No MIL came on, but I did notice a lack of power and my fuel consumption went up.
    I only scanned the car a few days later, and then found the thread linked about, so cleared the code and drove for a few more days, and then rescanned.
    The error was back, and other than a slight loss of power, and the worsened economy, there were no other symptoms or error codes in the engine module.
    I asked my tuner what he thought, and he suggested we reflash the car back to stock, except leave the DPF coding since I'd already removed mine.
    Anyway before I'd gone to reflash to stock, I was sat in the car just going through long codings and to clear the error again, and I saw that "DPF installed" was ticked.
    I unticked it, and applied the new coding.
    Since then, the car has been back to normal, and economy is better again.
    Hopefully no-one else suffers this, and I've told my tuner that if he does a B8 again, he must change the log coding as well as code out the DPF regen.
    NHN likes this.
  2. NHN
    29,517
    1,765
    Well done for reporting back for others.
    gary_a4_quattro likes this.
  3. viceroy
    284
    76
    Well the error came back, but performance and consumption are unchanged, so I'm going to guess at more than one issue.
    Code is almost identical except for the underlined number
    It was:
    It's now:
    Does anyone know what that number indicates?
    As for the error, I just happened to have the GoPro filming my gauges on the same drive when the error happened.
    Full throttle
    3rd gear.
    "Tiptronic" mode (+-)
    Just before or as the car changed up to 4th (I didn't change manually)
    This morning, there was no error as I was in 'S' or 'D' the whole time.
    Tried a 2nd gear blast changing up to 3rd in 'S' which didn't trigger the code, so to night I'll try a 3rd gear blast in 'S' to see if that triggers the code.
  4. mik15
    mik15 New Member
    resurrecting this old topic, but i am having a similar issue after remapping, have you in the end sorted it out? Which long coding have you changed?
