  1. Jolepatrol
    Jolepatrol Member
    33
    So I keep pulling a P1292 code and I think my fan runs even when its not so hot or even the temp outside is cool...and I wanted to know what to check BEFORE I go about thinking it's the actual thermostat itself. I have replaced the coolant temp sensor behind the engine by the firewall and that has fixed my screwy temp gauge. Also if it happens to be the thermostat I have an extended warranty and would this be covered?
  2. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    From the Ross-Tech website:
    [h=2]17700/P1292/004754 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit[/h] [h=4]Possible Symptoms[/h]
    • Malfunction Indicator Light (MIL) ON
    [h=4]Possible Causes[/h]
    • Fuse(s) faulty
    • Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265) faulty
    • Map Controlled Engine Cooling Thermostat (F265) faulty
    [h=4]Possible Solutions[/h]
    • Check Fuse(s)
    • Check Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265)
    • Check/Replace Map Controlled Engine Cooling Thermostat (F265)
  3. Jolepatrol
    Jolepatrol Member
    33
    Ok, so it's basically the thermostat? :/
