  1. auditj
    auditj New Member
    I reseted this code 2 days ago and it came back
    16398 - Bank 1: Camshaft B (Exhaust): Retard Setpoint not Reached (Over-Advanced)
    P0014 - 001 - Upper Limit Exceeded
    is there a way i can check timing using vagcom? i did the group 96 test and it said system NOT ok but ill change the cam sensor to see if it clears
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    it might help if you put what engine it is too :)
  3. auditj
    auditj New Member
    sorry its a 3.0 AVK
  4. stu_m
    1,441
    I know for the 1.9tdi in vcds you can go to engine measuring blocks group 4 and the last one is syncro angle this tells you how advanced or retarded the ignition is
    It's worth a look not sure if it will be the same for yours
  5. auditj
    auditj New Member
    What range would be a good value?
