oxygen sensor heater circuit
aviel131 Dec 6, 2013
  1. aviel131
    aviel131 Member
    104
    hello
    my ecu gives fault code: oxygen sensor heater circuit bank 1 sensor 1
    i replaced the sensor and the problem not solved
    what can fix this problem?
  2. jay1601
    jay1601 Well-Known Member
    1,347
    73
    did you replace the correct sensor, you may have 2 depending on engine.
    new or used part ?
    fitted correctly ?
    damage to wiring/block?
  3. aviel131
    aviel131 Member
    104
    hello
    its used o2 sensor
    i see damage to the wiring from the ecu near the o2 sensor
    they have cut and stripped together with glue.
