Owners 2.0T FSI Quattro question
Steve-L Aug 2, 2007
  1. Steve-L
    Steve-L Member
    93
    Can you get to 60mph in 2nd gear, mine gets to about 55ish (speedo reading) before it redlines ?
  2. siu00adg
    siu00adg Member
    997
    My 2.0FSI gets to about 62 on the speedo in 2nd gear, but I think the speedo reads 5 or 10% higher than I'm actually going.
  3. steve184
    steve184 Active Member
    1,138
    this is strange as most petrol cars are geared to be able to do 60 in second purposely to give it a good 0-60 time - this is the reason why diesels have such abismal 0-60 times in comparison as they need two gearchanges (and god do you waste time changing gear - you don't half realise this with the s-tronic box)
  4. Dandle
    Dandle Member
    852
    Mine won't do 60 in second. They dont gear cars to purposely do 60 in 2nd, some cars can do it others cant. I find the gears on the A3 to be very short especially 6th which should have been a cruising gear and give better economy on a run.
    My T4 needs 3rd to hit 60 as well.
  5. Cupramax
    Cupramax Uber pimp meister
    457
    Its the quattro's, they run a very slightly shorter set of ratios than the 2wd cars due to the extra weight of the 4wd. Hence old S3's wouldn;t reach 60 in second either and the new 2.0TFSi is no different.
  6. RobinA3
    RobinA3 Well-Known Member
    1,825
    43
  7. OutLore
    OutLore VOIP Dude
    1,206
    Don't know about whether mine (S-Tronic) will hit 60 in 2nd or not, but my speedo is GPS accurate to 1mph up to about 90....
