overheating problem can anyone help ?
andy1 Oct 4, 2013
  1. andy1
    andy1 Member
    95
    Hi i own a 03 audi s3 8l (i only bought last night ). I drove the car home with no issue but today ,y temp gauge went sky high and my exhaust is starting to smoke really bad.. anyone any idea of the cause ? Thanks
  2. hendry10
    hendry10 Member
    69
    21
    I take it You must have lost water then too ? High temp and steam -
  3. hendry10
    hendry10 Member
    69
    21
    Normally would point to head gasket or a cracked head as the coolant is getting into the cylinders and being spat through your exhaust , a compression test will tell u .
  4. andy1
    andy1 Member
    95
    Hi thanks for the reply ive had no loss of water ive also found a burst hose coming from a little plastic valve thats attached to the head (btw im not very technicsl minded sorry )
  5. <tuffty/>
    21,375
    3,937
    Water pump would be my suggestion... they have a habit of having the impeller break into pieces... should be changed at the same time as a cambelt really.. if yours hasn't then its most likely that...
    The housing on the side of the head is around 12 quid from a dealer... its common for them to split... had one let go on the dyno before...
  6. andy1
    andy1 Member
    95
    Thanks mate do you any idea of a price for both supplied and fitted ?
