overboosting problem 1.8t agu
GeoA3 Nov 29, 2012
  1. GeoA3
    GeoA3 Member
    85
    my car is chipped and should boost 1.4bar,for a while it boosting 1.6
    i disconnect the two electricity wires that connected to the n75 valve and went to test drive
    now instead of boosting 0.5 bar the car still boost 1.6bar!!!
    any ideas?
  2. Lewis583
    956
    91
    Check all vac pipes on the same line as the wastegate actuator
  3. Prawn
    11,603
    3,577
    sounds like the pipe from the actuator to wastegate has come off somewhere, or possible from charge pipe to N75 and causing a boost leak as well.
    that's the only explaination if you're getting above actuator pressure with the n75 disconnected
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Actuator damaged /semi siezed...... wastegate siezed/partially siezed .........bent actuator rod....
  5. GeoA3
    GeoA3 Member
    85
    how to check the actuator?
  6. GeoA3
    GeoA3 Member
    85
    ok i just checked the hose from actuator to the n75 and was cracked , the rubber was hard like a rock o_O!
    lucky i have a tons of silicone hoses from ebay, everything works great now . :)
