Overboost condition 2.0 tdi Vagcom results inside limp mode
kdotman Feb 16, 2011
  1. kdotman
    kdotman Member
    41
    i was on 3rd gear. from about 1500 revs to 4000
    Does this show overboost. it has only happened twice up a hill
    car is remapped
  2. dunk
    dunk Member
    770
    overboost is usually sticky vanes in the turbo - needs a good clean and probably ultimately a replacement turbo.
  3. NHN
    29,509
    1,764
    If I could see the numbers would comment lol
  4. kdotman
    kdotman Member
    41
    this was from about 1500 to 4000 revs in 3rd gear
  5. NHN
    29,509
    1,764
    Boost seems all over the place there mate, under & over in the split seconds its logging, I would check all components along the way from airbox through to intake manifold, which of course includes the turbo, which is 1 of the most well known culprits, but need to work along & see which one makes any difference, noticed you had egr fault aswell, have you checked vacuum pipes & egr movement/components which are also at the back of the engine right side which has cooler & actuator iirc.
  6. kdotman
    kdotman Member
    41
    Thats what i thought.. Yeah the only error i have is egr insufficient flow and turbo overboost condition
    Could it be a bad remap.. the people that did it were www.mobileecuremapping.co.uk
    What items can i check before i get the turbo refurbed? i can only see vacuum pipe to the egr
