hey guys.
car currently sits at the usual 5psi limp mode.
vag com brings up a fault code about fuel trims over fueling etc
suspected a boost leak somewhere, so had a quick look around and noticed that the intake pipe was half hanging off the turbo as the hoseclip had undone its self
ah ha! problem found...
tightend that back up but it reset the codes and it was fine for all of 15 mins.
dont have a boost leak/smoke tester at the moment, so wondering if there is anything else i can do/test in order to narrow down the fault incase its not an air leak?
dodgy sensor? lambda etc?
have vag com, but dont really know the correct blocks or what they readings should be.
2002 8L S3
many thanks
Sam.
2002 8L S3
many thanks
Sam.
