over boost
ash3435 Sep 9, 2010
  1. ash3435
    ash3435 flat out if in doubt
    148
    my cars been boosting really high over the last few days 26-27psi.this has only come about as ive found a boost leak on the pipe coming off the turbo and its now fixed.ive logged the n75 and all seems to be ok 94.5.no fault codes.this doesnt happen all the time but im worried ill bending a rod.boost usally around 24 mark.ive even changed my settings on revo to just performance and still the same.plz help
  2. <tuffty/>
    21,002
    3,767
    Have you logged requested boost vs actual boost on a run with vagcom? 27psi is far too high, dangerously so... 94.5% duty cycle is awfully high if thats what it is all the time... the duty cyc;le will spike on initial spool to get things going but IIRC shouldn't be that high... try disconnecting the N75 electrically... it will throw a fault code but this will effectively run on actuator pressure... if you are still getting 27psi then you may have a problem with the pipework off the N75 to the actuator or the actuator itself...
  3. ash3435
    148
    ok ill go do the log of 118 020 002
  4. <tuffty/>
    21,002
    3,767
    make that 031 (lambda request vs actual),115 (boost request vs actual),118 (N75 duty cycle) mate.... usual shizzle, engine temp 90 degrees, third gear run from 2k rpm to as fast as legally possible, screen shot the run and post :)
  5. ash3435
    148
  6. ash3435
    148
    thats better.not posted for a while.this is after a few runs, so the intakes a little hot.turned the timing down as i was getting 8.on timing 4 on the sps plus now.timing was on 7.ill post the previous log
  7. ash3435
    148
  8. <tuffty/>
    21,002
    3,767
    Getting a lot of timing pull there mate, I would tweak the timing advance down a bit... occasional 3's and rare 6's are ok but you are getting them a little too often...
    Looks like you are getting your boost spike from just over 3k to 4.5k... getting a load of timing pull around there too
  9. ash3435
    148
    this is the fueling for the first run, when timing was 7
