Outer CV joint boot clamp
voteforpedro Nov 23, 2008
  1. voteforpedro
    voteforpedro Member
    632
    Where can I get a decent CABLE/ZIP TIE of suitable thickness and length for the outer (wider) end of the outer CV joint boot? I trecked down to Maplin and got their longest ties and, well, they weren't long enough. It's just a temporary fix until I can get the real "Oetiker" clamp on.
    Do Laser do a proper tool for the Oetiker clamps which I can pick up from GSF or Halfords etc?
    Alternatively, any tips for getting the Oetiker clamps on without the tool?
    Failing that, where can I get a zip tie which will fit? I just want to get it sealed temporarily and I will get the garage to fit the Oetiker clamp when I MOT it.
    Thanks. :)
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    i doubt zip tie will hold it on properly, if its not long enough why not double up on the ties in other words thread 1 end of zip tie through another then wrap around gaiter the cut off both ends
  3. rasA4
    3,287
    119
    ah just noticed you have already posted this thread again, prob due to the site being slow.
    MODS PLEASE DELETE
  4. Broken Byzan
    13,244
    468
    Zip ties work well tbh, some kits are actually supplied with them As long as the CV itself is clean of grease as is practical and it will hold
  5. rasA4
    3,287
    119
    had a bad experiance with them of the wifes car, i think it would be ok if fitting them from NEW, however on her car must have slipped off and the boot had been hanging off for a month after i bought the car and the boot had got 'used' to that position, luckly it had not damaged the CV.
    so when i tried to zip tie it back drove it a few miles and it had come off tried it a few times kept coming off, so had to replace the boot in the end.
  6. Broken Byzan
    13,244
    468
    That will be the grease making it slip,if the grease is removed it sitcks/grips just fine
  7. rasA4
    3,287
    119
    not really mate i made sure it was clean and dry after the 1st atempt.
    the boot had fallen off the bit where it would normally strap onto there was some resistance trying to keep it on. just my experiance which i know is minimal compared to yours mate.
  8. rasA4
    3,287
    119
    this thread has been posted 3 times now
