Outer CV joint boot clamp
voteforpedro Nov 23, 2008
  1. voteforpedro
    voteforpedro Member
    632
    Where can I get a decent CABLE/ZIP TIE of suitable thickness and length for the outer (wider) end of the outer CV joint boot? I trecked down to Maplin and got their longest ties and, well, they weren't long enough. It's just a temporary fix until I can get the real "Oetiker" clamp on.
    Do Laser do a proper tool for the Oetiker clamps which I can pick up from GSF or Halfords etc?
    Alternatively, any tips for getting the Oetiker clamps on without the tool?
    Failing that, where can I get a zip tie which will fit? I just want to get it sealed temporarily and I will get the garage to fit the Oetiker clamp when I MOT it.
    Thanks. :)
  2. aragorn
    18,296
    804
    i usually just fit two zip ties chained together...
    The important bit is ensuring the rubber boot and the seating surface is properly grease free, if it is it'll stay on just fine with cable ties.
  3. Broken Byzan
    13,237
    465
    or alternativly ^^^^
  4. Siena
    Siena Active Member
    2,626
    ...^^^^ Mark'll help you out.
  5. Broken Byzan
    13,237
    465
    I have hostage grade :salute:cable ties in stock as it happens, if the OP PM's his address i can post him one for free
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    you can get the proper metal ones form Murray Macdonalds IIRC
