OT EGR valve plate for corsa
rasA4 Feb 11, 2009
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    sorry for posting on here, but im sure i would get a better response here
    the wife's dreaded 2001 corsa has come up with the egr valve alarm again seen this on eBay Linky
    they seem to work has anyone used these plates?
  2. aragorn
    18,436
    845
    the only issue would be that if the valve is faulty, the ECU will still see the faulty valve, and it will still run in limp mode...
  3. Broken Byzan
    13,237
    465
    Its a standard thing to do on many new cars now, bypass them. As long as what he says is correct and leaving it connected will stop it faulting, then you are good,however seeing as you already have a code showing it may be too late.
