Original Audi number plate LED's that fit the A3 8P - plug & play!
klik Mar 30, 2012
  1. Xerohour
    Xerohour Active Member
    220
    31
    Hi Guys,
    Ive been away from the forum for long time and came on as i noticed a number of new audi's driving around with LED reg lights. I figured that someone must have given it ago on here and you never fail to amaze me!
    So can someone help and let me know if i can order the A5 Led replacements for my A3 Black Edition?
    Its a 59 plate but was delivered in Jan 2010 if this helps.
    Thanks in advance!
    Nick
  2. A3_Black_Edition
    A3_Black_Edition Member
    417
    19
    I am also interested in finding this out. I have a 2012 A3 Black edition.
    Also I wondered how you contact TPS for part prices?
    Cheers,
    Si
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    It's been covered this in thread for MY10+ cars
  4. A3_Black_Edition
    417
    19
    Thanks, I will read the whole thing soon then.
    Cheers,
    Si
  5. Xerohour
    220
    31
    Forgive my ignorance, but i have no idea how what constitutes a MY10+ car.
    I would also challenge any new comer to this forum to have the faintest idea what has just gone on over the last 8 pages!
    Any help is greatly appreciated.
  6. A3_Black_Edition
    417
    19
    Basically read the last few pages... You buy the part numbers suggested but to get them to work you need to get them coded to the car.
    Cheers,
    Si
  7. djsherif
    djsherif New Member
    13
    Yes I'm having a hard time figuring out which area in VCDS I go into to change these settings.
  8. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,074
    765
    go into 09 central electronics, then click coding and follow the guide in this thread.
  9. N8
    17,163
    719
    My coding guys is F5821F11B01410004D0000006400000000096E135A16021E000000000000
    It's not working on mine, mine is a MY08.
  10. L1ARR
    L1ARR Active Member
    437
    44
    Where has lala30 gone when you need him?
  11. N8
    17,163
    719
    Tell me about it! :laugh:
  12. NHN
    29,563
    1,779
    The coding is only available on the newer CE boards, it does show up on newer cars in VCDS now, its an option that would tell the car that circuit is running led's as in it will either lower the tolerance required to consider a bulb blown or it will disable that system check feature, so it doesnt check when cold or hot circuit, I'm going with the 1st option so it still knows if its working or not.
    Its just pure luck the tolerance on some older cars is good enough to notice the led's fall within spec to not trigger the bulb blown warning.
    N8 your car will need to have circuit modification, resistor pack probably added imho, to get rid of the warnings if its triggering yours.
  13. N8
    17,163
    719
    Really? I have LEDs in there at present, they work fine, looks like I'll be selling mine then :laugh:
  14. NHN
    29,563
    1,779
    You said it wasnt working on mine, so by that assumed you meant the led's were warning on your dis.
  15. N8
    17,163
    719
    Yes the Audi LEDS aren't working and I have an error light, but my old LED bulbs work without a hitch.
  16. NHN
    29,563
    1,779
    Send them to me I'll have a play lol.
  17. t8ups
    2,074
    765
    N8, adjust the clips on there to make sure the prongs are making contact, all the ones i have fitted didnt work without adjusting and they should work.
  18. N8
    17,163
    719
    I'll have a go brother ;)
  19. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    422
    26
    my long code is 4E000A2FA017F0C0207041E00100095C427E2BAA206DD12AE4008F840041 and my BCM PQ35 M 107 0615. is it possible to code my 2011 BE to work with audi LED number plate lights????
  20. Jambo26
    422
    26
  21. lala30
    lala30 Member
    35
    10
    your long code for led is :
    4E000A2FA017F0C0207041E00100095C42FE2BAA206DD12AE4008F840041
  22. Jambo26
    422
    26
    i tired this last night but it wouldnt code in.
    Just tried again wont accept code.
    BCM PQ35 M 107 0615. isthe 0615 the SW so this means i cant code LED number plate lamps in
  23. Jambo26
    422
    26
    is this correct. if so is there any think i can do to keep the leds without the bulb out error. possibly resisters or something
    cheers
  24. NHN
    29,563
    1,779
    Go through your module coding & check for the tick box for led lights installed, if its not shown, its more than likely its not available on that board, although sometimes there are tickboxes not shown for your module that may work with manual hex coding, but you have to be careful you dont code something thats not reversable.
  25. N8
    17,163
    719
    They are so much shorter the prongs than my other holder.
  26. Jambo26
    422
    26
    i tried to code FE from 7E but it wouldnt code in just reverts back to 7E. also it doesnt some just bit 7 which i think is what im trying to enable. also trying the foot well LED. but still brought error in dis. is there a way i can still use these genuine lights without coding and without errors??
  27. t8ups
    2,074
    765
    You footwell lights as LED wont error in the DISm there is something else causing that error.
    With the coding when changing, try change the code then clink onto another byte rather than pressing ok as it sometimes wont change.
    N8, you need you just bend them higher and they will work for you bud.
  28. Jambo26
    422
    26
    Managed to code it up this morning but still got a bulb out error on number plate.
  29. PH1L
    PH1L Gievf Buckets
    3,851
    40
    they need a lot of adjustment brother, i had to take mine out a few times before i got ti just right
  30. N8
    17,163
    719
    Yours working 100% brother?
  31. PH1L
    PH1L Gievf Buckets
    3,851
    40
    yeah they turned off every now and again because they were loose but got that sorted, whats going on with yours like?
  32. N8
    17,163
    719
    I'll look at it with my brother, come the weekend, he's up and we'll be detailing the car ;)
  33. PH1L
    PH1L Gievf Buckets
    3,851
    40
    cool im only a phonecall away bud its simple enough though
  34. Jay.Ing
    Jay.Ing Active Member Team Ibis Audi A3 Black Edition TDi
    345
    61
    So after spending hours playing round with my new VCDS lead (Thanks NHN!) I've finally got the bulb warning to turn off in my DIS! :)
    So for all you people who want to try it take a look at this how to!
    So first of all after you have ordered your OEM LED's 4H0 943 021 and 4H0 943 022 remove your old lamp units and COMPARE them. You will see that the LED ones have shorter contacts.
    Bend the contacts to a straighter alignment so they look similar to this:
    Then install them into place. You can use them like this but you will get a DIS warning.
    [​IMG].
    CODING.
    I have to thank lala30 for the research he did as i wouldn't have been able to put this together without his research.
    So boot up your VCDS and head on over to 09 - Central electrics module.
    Check for any fault codes before you start.
    Open up the Long coding and then long code helper, make a copy of your long code in paragraph1) (keep it somewhere safe)
    Click on byte 17 in paragraph 3)
    Right the key here is that if you look at my screen shot i HAVEN'T got Bit 7 (The one you meet to sellect to turn off bulb monitoring), the key here is to ignore the bits and look at the binary box this is where i have got 8 bits (0-7) so turning the first digit to '1' is the equivilant to ticking the bit box '7' (Binary is read backwards and starts at 0)
    BEFORE
    AFTER
    Close the Long code helper and save the code.
    After this i turned the ignition off and back on again, turned the lights on and…………………………….. NO BULB WARNINGS!!!
    I have a 2012 sport back BE so i don't know if this method will work with all but hey, worth a try in it!!!!!
    Thanks again to lala!
  35. N8
    17,163
    719
    Who wants to get mine working at AITP? :)
  36. Jambo26
    422
    26
    il have a go at the binary, i thouht my 2011 be would be able to code u no problem, love the look of the oem plate lamps just not the bulb error on dis.
  37. N8
    17,163
    719
    Mine don't even light up :laugh:
  38. poli84
    poli84 Member
    425
    57
    Thanks for the clear write up Jay.Ing, it's really appreciated.
    I'm going to order these bulbs and give it a crack on my MY10.
  39. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you got them in the right side lad? if you dont they wont work
  40. A3_Adam
    A3_Adam Member
    64
    Tried to get them working on my 53reg A3 ready for Aitp but had mixed results. Left one wouldn't light up at all but the right one flickered, stayed on for a few seconds then nothing. Any ideas?
