Original Audi number plate LED's that fit the A3 8P - plug & play!
klik Mar 30, 2012
  1. lala30
    lala30 Member
    35
    10
  2. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
  3. Virdee
    Virdee Active Member
    172
    25
    Ordered. Will be with me tomorrow
  4. Acheron
    Acheron Active Member
    271
    30
    Hmm, now I wonder if this would sort out the DIS message I have with the ebay LED lights I installed (which were supposed to work from 2003-present, but kicked up the bulb out error on my 2010). :uhm:
  5. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Im gonna plug my VCDS in and see if this coding woks with non-OEM ones aka eBay.
  6. Cruiser89
    1,484
    222
    Just checked and I have no bit 7 available, unless it only shows with the OEM modules? Can you confirm Lala?
    I have some on order from TPS which will be here in the morning.
  7. lala30
    lala30 Member
    35
    10
    yes I write before to ross-tech no open this bit, and only see 6
    if you have BCM SW 651...
    send me your log and I make good coding to work
  8. Cruiser89
    1,484
    222
    Ok...
    Changed the FE to 7E, cleared the fault codes and will monitor. Bearing in mind these are aftermarket ones.
    Lala... Do you know what this bit does exactly? Will it affect anyhing else apart from the license plate holders? Don't want a blown brake light and not know about it.
    Cheers fella.
  9. lala30
    lala30 Member
    35
    10
    this is bit only for LED number plate
    your code bite 17 is like my FE
  10. alexandru
    alexandru New Member
    I have a problem. My car is a MY11 and at for the byte 17 I only see 6 checkboxes and in my long coding I have 1E and not FE or 7E. How can I solve the problem ?
  11. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,079
    768
    in your video you get the error out on cold diagnostic, to my knoledge that mean when you turn the igniction on it does a check, so what does the error happen while you are driving as it does its checks as that would be warm diagnostics?
    i have done coding on BMW's and when you turn the diagnostics out if the bulb was to blow it wouldnt even tell you anymore.
    is this the case in this coding?
    Trups
  12. lala30
    lala30 Member
    35
    10
    I make code after and post hear
  13. lala30
    lala30 Member
    35
    10
    your code is : 9E
  14. alexandru
    still not working :((
  15. lala30
    lala30 Member
    35
    10
    you have SW ? in BCM
  16. Virdee
    172
    25
    Lala30 - legend!
    Just to inform people, works on MY12 by changing the byte 17 bit 7 as mentioned in this thread
    Led lamps work, and no error on DIS.
    Finally OEM LED lamps! Thank you very much.
    Btw I had to bend the contacts so they would sit higher, as when I first installed them, they didn't work.
    S. likes this.
  17. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,081
    575
    yes, those contacts are short. be sure that the bend sits nicely on cars contacts and screw it in tightly.
    lala30 saves the day :D
  18. Cruiser89
    1,484
    222
    What part number did you order buddy? Got mine from TPS today and it had no lugs, just a connector. Bit bizarre.
    I can also confirm it works with aftermarket LED lights!
  19. amar06fbr
    1,055
    68
    lala your doing some good work here, keep it up mate. :superman:
  20. HSP
    HSP 3rd Gear
    32
    9
    Lala, I only have six options on in byte 17 , the long coding that i have is 76. how do I change??
  21. lala30
    lala30 Member
    35
    10
    I send PM
  22. Virdee
    172
    25
    The ones listed at the start of this thread. Can't be ***** to check, but something like 4H0943021/2
  23. rennie
    rennie Member
    32
    My Stoke Audi order:
    [TABLE]
    [TR]
    [TD]Audi A5 LED number plate light (Left)
    [TABLE]
    [/TABLE]
    [/TD]
    [TD="width: 100"]4H0943021[/TD]
    [TD="width: 100"]1[/TD]
    [TD="width: 150"]£10.01 UKL[/TD]
    [TD="width: 200, align: right"]£10.01 UKL[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]Audi A5 LED number plate light (Right)
    [TABLE]
    [/TABLE]
    [/TD]
    [TD="width: 100"]4H0943022[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD="align: right"]Subtotal:[/TD]
    [TD="width: 100, align: right"]£20.02 UKL[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD="align: right"]Shipping:[/TD]
    [TD="width: 100, align: right"]£3.90 UKL[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD="align: right"]Grand Total:[/TD]
    [TD="width: 100, align: right"]£23.92 UKL[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD="align: right"]VAT Included in Total:[/TD]
    [TD="width: 100, align: right"]£3.99 UKL[/TD]
    [/TR]
    [/TABLE]
  24. Cruiser89
    1,484
    222
    Weird. That is the exact part number that I ordered and it came without the metal contacts.
  25. Kelvin_S
    Kelvin_S Member
    243
    Weird, what part number is on the LED?
  26. poli84
    poli84 Member
    425
    57
    Well done guys, this is great news.
    Now, can someone please do a write up of the changes that need to be made?
    The information is all over the shop and confusing.
  27. White Audi RS3
    White Audi RS3 New Member
    17
    I have allready those OEM LED lights and they give an error. I need also clear instructions.
  28. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    fitted mine today on a 54 plate a3 tdi works a dream.
  29. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    422
    26
    hi guys,
    i wanting to get a pairof these audi LED lamps for my 2011 A3 Black Editon and wondering if any one is near Carlisle UK who could code in my LED lamps???
  30. mike foster
    3,967
    Check VCDS user map for help in your area.
  31. Jambo26
    422
    26
    just wanting to know on vcds where to go and what to do. goona ask and ex techy i know to code these lamps up. just thought if i know what im doing can explain better to him and tell him what he needs to do if he doesnt know??
  32. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Confirmed fitted and working without error on MY2008 A6 (prefacelift)
    Bought from Kelvin_S due to one of them not working in his A3 - but weirdly both worked in my A6 :)
    Will provide a night shot later ;)
    Anyway heres the pics
  33. lexpat
    lexpat New Member
    So do we have more feedback for 2010+ cars?
    L1ARR likes this.
  34. Virdee
    172
    25
    Yes I posted and confirmed that they work in my MY12 car with the appropriate long coding in CE 09.
  35. a6_chris
    1,883
    160
    Not sure why they didn't work in your car, I didn't even adjust the pins either just put them straight in and both lit up.
    Thanks anyway ;)
  36. White Audi RS3
    17
    Is it possible for someone to give me clear instructions, how can I get these OEM LEDs to operate without the fault codes? Thanks...
    My car is 2011 RS3.
  37. a6_chris
    1,883
    160
    Read back a couple of pages and you will see as long as you have vcds.
  38. Cruiser89
    1,484
    222
    Can you remember what part numbers you ordered bud. I ordered some for my A6 and it came with these weird connector blocks and not the metal pins like my A3 has (I have aftermarket on my A3 and as its a work car they can't be that bright).
    Ta
  39. a6_chris
    1,883
    160
    I will pm if you want and I can send you night shots as I don't want my full reg online ;)
  40. Cruiser89
    1,484
    222
    Thanks pal...
    Gonna email TPS tomorrow and get them in.
    That would be good bud. Thanks.
