Original Audi number plate LED's that fit the A3 8P - plug & play!
klik Mar 30, 2012
  1. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    420
    25
    I seen your thread about the load resisters but hoping I can sort my problem with just some software and coding upgrades. But if no joy il be doing the load resisters.
    Jamie
  2. eddyd
    eddyd Member
    99
    Can your ex tech not look up the TPI number Jamie?
    Audi dealership may also do it under warranty.
    Found this on another forum for upgrade bcm 615:
    TPI 2029738 (SVM code 09A008)
  3. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    560
    41
    After being initially overexcited and buying a pair thinking they might be plug and play in a b7 A4 too these are now abandoned and for sale. PM if interested. Never mind :)
  4. Reload
    Reload Bird is the Word!
    367
    49
    Anyone mind if I have a quick gloat and say they worked perfectly in mine and look fantastic. Mmmm, smug mode! :cool:
  5. Jambo26
    420
    25
    Is that to upgrade to BMC 615. & I think the smv code could be the trick I think from what I can make out its a code to access the control module I think.
  6. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,756
    Right. Confusion abounds.
    I have a MY2011 car, 60 reg, with the CE 0615 controller. The one that is allegedly giving lots of confusion.
    As lala30 suggests, the latest version of VCDS gives that elusive Bit7 in Byte 17, so the first step for anyone wishing to do this is to download the latest version of VCDS.
    My CE 0615 seems to have taken the new coding, so, in theory, will not give me a DIS error when I install the A5 LED lamps! Unfortunately, although I've made the change in my CE controller, I don't have any LED lamps to hand to test!! So unless someone else with lamps, and with a CE 0615 want to test this, you'll have to wait till I get some LEDs later in the week!
    But here's a screenshot of the latest VCDS version, with the CE 0615, which seems to have accepted the new Byte 17 Bit 7 coding.
    Ciao!
  7. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    589
    100
    43
    I can try this out on mine in the morning - I have the LEDs sitting on my desk and only realised I had the 0615 module after a VCDS check. Just installed the latest VCD release.
  8. veeeight
    6,849
    4,756
    The hopes and dreams of every BCM owner pre 0651 rests upon you this morning!!
  9. downtothebone
    589
    100
    43
    No joy for me on my 2011 model with 0615 controller. The controller accepted the bit 7 change and the LED lights came on so no contact issues but DIS threw the bulb error ... :(
  10. veeeight
    6,849
    4,756
    Crushed :(
  11. Jambo26
    420
    25
    I got excited reading the above about having the option for plate lamps :(
  12. eddyd
    eddyd Member
    99
    That is to upgrade from BCM 615, there is another code and TPI to upgrade to BCM 615.
    If you google either the TPI or SVM codes, there is loads of info on the German forums, all 2011+ cars can be upgraded quite easily now.
  13. Jambo26
    420
    25
    Do you know what it updates to???
  14. daz.h
    daz.h Member
    59
    i have an 07 a3 1.9tdi i assume (rightly or wrongly) that these will fit straight in, i have read that i'm likely to have to extend the contacts etc, but all this info about codes etc is going straight over my head.
    so if these will work, where's the best place to get them?
    or is anyone fed up of trying to get theres t work?
    daz
  15. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,905
    483
    you can get them from audi parts dealer or ebay i saw few sets for sale when i was searching stuff...
  16. daz.h
    daz.h Member
    59
    thanks i'll have a look.
    while on the subject of led's would the a3 led lights fit an 07 plate car, or would it need to be coded?
  17. scotty0189
    scotty0189 Prepairing to Land
    72
    Hey Daz, I did this a couple of weeks ago. It was just plug and play, no coding, no extending just remove and replace. That was on my 57 plate A3
    Oh and I got the bits from Audi using the part numbers given earlier in the thread :)
  18. daz.h
    daz.h Member
    59
    Thanks scotty, i'll call them in the morning and ask, i'd rather get original stuff if possible
  19. scotty0189
    72
    Not a problem Daz - glad I could help. OEM is the future :)
  20. daz.h
    daz.h Member
    59
    called my audi dealer in york today and they said them part numbers are not for an A3 model, and that they will not work as the voltage is different :think:
  21. NHN
    29,282
    1,692
    You should of told them to ring the worlds 7 wonders hotline & said you have the 8th wonder, they can talk out of there asse lmfao
  22. N8
    17,163
    718
  23. ferda25
    ferda25 New Member
    I could upload to BCM unit from software version 5xx last version of software with index highest like 65x..More information through personal message.
  24. daz.h
    daz.h Member
    59
    picked original ones up from audi dealer in york, took 3 goes to get them to work, terminals are almost straight.
    looks a nice clear white though, :icon_thumright:
  25. neilwaterhouse88
    neilwaterhouse88 Member
    54
    Hello I have tried to get the genuine lights working on a 2010 a3 and am still getting error messages after changing bite 17 bit 7 any ideas
  26. Jambo26
    420
    25
    What BCM do you have fella. if you have lower than 651 then the coding wont work, im in the same boat going to try updating mine at some point with the above info.
  27. neilwaterhouse88
    54
    Im not sure will have to check, I'm probably being stupid but how exactly would I update it?
  28. Jambo26
    420
    25
    you need VAS what the main dealers use. theres a ex techy that set up on his own nearme that has vas and he said he can do it just needs a smv code. so im gonna try the one listed above see what happens. i think the main dealer will the able to do this aswell
  29. nshort10
    nshort10 Member
    122
    14
    Hey guys
    Picked my a5 led lights up from Audi yesterday. Fitted them and got the warning light. Spoke to a mate of minemandnhenpassed me on a boys number. Met him and he got the warning light off! Cost me £20 though but least it done and dusted!
    Looks amazing!
  30. Jambo26
    420
    25
    how old of a car fella? do you know what he did, what he used??
  31. mike foster
    3,967
    It would be far more useful to everyone if you said what was done rather than boasting about the fact that you had got it done !
  32. nshort10
    nshort10 Member
    122
    14
    Mike foster, I'm not boasting I took the info I gathered from this forum, took photos of the information people posted and screen shoots of there vcds and showed it to the boy. I left the car with him for about 15 mins. So I used all the info I got from this forum.
    He said the coding I had showed him didn't work on my car but he had figured it out.
    If you want his number I can give you it he based in glasgow and he works for a major vw/Audi garage!
    I have no idea what he did or coding he used, if I did I would of posted it to help people out!
    If people want his number let me know and you guys can call him.
    He in glasgow
  33. nshort10
    nshort10 Member
    122
    14
    It 2012 rs3 mate
    I took all the screen shots from jay.ing showed him he tried those coding but never worked on my car he messed about with for about 15 mins and figured it out.
    I have no idea about coding or anything like that mate, I can't be of any help but if your in glasgow can give you his number and you can go see him.
  34. Jambo26
    420
    25
    well im not to far away kinda im in carlisle. i might give him a ring and ask a few questions
  35. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    1,941
    679
    Looking at what he wrote i dont think he was boasting Mike.
    he just wanted to share he had the error taken off his new car.
    Trups
  36. mike foster
    3,967
    Fair comment but that's not much help to other forum members is it? Probably gets them even more frustrated.
    I don't have, or want, led number plate lights but I know you sell them and I know loads of members have problems with them.
    Seems to me that most of those problems are to do with DIS errors (including the ones you sell I believe) so in my opinion it would be much more helpful to the members with problems to publish the answer rather than just say they had it fixed !
  37. Jambo26
    420
    25
    it is a little annoying but also good to see people are getting the errors sorted. i have dis errors and trying to sort this out. so his info is helpfull that the guy who fixed his could possible have the answer most people want to know.
    i dont think he was boasting just informing us he has got error free oringinal audi A3 plate lamps.
  38. mike foster
    3,967
    The point of the forum is to help people sort out problems ( I think ?? ) OK so he wasn't boasting but what is the point of posting without details ?
    You say you are not far away from the guy who sorted it out and you might be able to contact him for details of the fix so please publish the results for the benefit of all who are interested.
    t8ups - I would have thought you would have wanted to talk to this guy in order to help out any customers of yours that are having problems ? Having followed this thread for a long time it would appear that, whilst the quality of your products are not in question, there are still issues to be sorted.
  39. Jambo26
    420
    25
    i intend to do so if the guy is ok with this, just waiting for nshort10 to get back to me. then i can get some info
  40. mike foster
    3,967
    Good man ! :icon_thumright:
