Original Audi number plate LED's that fit the A3 8P - plug & play!
klik Mar 30, 2012
  1. klik
    klik Member
    234
  2. L1ARR
    L1ARR Active Member
    424
    43
    Who will be the first to see if these work? Unfortunately I can't get to Audi until tomorrow.
    Sim_88 likes this.
  3. Reload
    Reload Bird is the Word!
    367
    49
    Good find, I will watch with interest on this one. It's one of the last LED conversions I need to do to mine
  4. jerseypaul
    jerseypaul Member
    241
    29
    I would be up for a set of these.
  5. fangio
    fangio Well-Known Member
    1,472
    174
  6. Tracebuzta
    Tracebuzta Member
    97
    Looks interesting.... Just emailed my Audi pusher :)
  7. Rob2k68
    Rob2k68 Well-Known Member Team Daytona Audi S3 quattro DSG
    6,496
    9,760
    My local dealer just told me that they are OEM A8 fit, £9.80 +VAT each but not available to order until the end of March which erm is tomorrow !!
    Might try again later in the week but good find :icon_thumright:
  8. Tracebuzta
    Tracebuzta Member
    97
    My dealer told me that they are from the A5 Cab :)
    He will try them on his own car on monday and get back to me :)
  9. Baffles
    Baffles Active Member
    229
    44
    Keep us informed! I think my Polargs are melting the housings..
  10. Acheron
    Acheron Active Member
    271
    30
    I've ordered a set, but I suspect they might be a little dim compared to the aftermarket ones.
  11. eddyd
    eddyd Member
    99
    Don't think they work in MY11 onwards either though, from what I've read.
  12. aky20
    aky20 Member
    68
    Has anyone managed to order these yet I spoke to stoke Audi and they are not available to order yet ?
    Cheers guys
  13. Tracebuzta
    Tracebuzta Member
    97
    They are available to order, and my dealer just confirmed that they work a treat on his ´06 SB :)
  14. Imteyaz
    Imteyaz 6th Gear
    535
    Are the SB units the same as the 3dr?
    If so, I'll be placing an order with TPS soon...
  15. PH1L
    PH1L Gievf Buckets
    3,851
    40
    3dr and sb are the same you can get these no problem mine should arrive today due to the snow i wont be fitting till tomorrow i have the 09 ce unit so that covers up to my11 if they work in my car
  16. 3DTDi
    3DTDi Member
    239
    Will ring dealer and order today and report back asap
  17. plezz
    plezz Member
    233
    9
    Hey P5SND, just to make sure i understand correctly, will these lights work in the 58 onwards facelift models? Mine is a 60 reg - october 2010 model, and was thinking of getting a set, but wasn't sure if they were for pre facelift models only.
    thanks,
    Plezz
  18. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it would depend on your ce unit do you have access to vacom? i dont even know if they will work in mine yet ^^ will let you know as soon as though
  19. xanderxxx
    xanderxxx Active Member
    105
    30
    any up dates on this one anyone ?:beerchug:
  20. 3DTDi
    3DTDi Member
    239
    Mine are on way to dealer apparently, will be a day or so now
  21. plezz
    plezz Member
    233
    9
    thanks Mate, i havent a clue on my ce unit unfortunately! and no Vag access either :( i'll just keep my eyes out for this thread and see how things develop and go from there! :)
    oem LEDs would be nice, i always feel a little safer putting them in as opposed to aftermarket stuff, even if they arent quite as bright.
  22. mike foster
    3,967
    Part number if anyone interested is :- 4G0 943 021 - cost £11.02 each
  23. PH1L
    PH1L Gievf Buckets
    3,851
    40
    I tried to order these Audi declined the order from tps! Took them till now to tell me
  24. mike foster
    3,967
    Try Dave at Stoke Audi.
  25. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    is that part number for both sides?
  26. mike foster
    3,967
    I assume so as ETKA shows 2 required with that number
  27. amar06fbr
    1,055
    68
    Phill! were you been hiding? havent seen you on here in ages..
  28. audigex
    audigex Active Member
    592
    45
    Very interested to find out whether these fit the my12 sb.
  29. Baffles
    229
    44
    I've asked Dave in the Stoke Audi section if he can get hold of them - so keep an eye on the thread.
  30. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Been a busy laddy tbh trying to kick back with big plans!
  31. Rob2k68
    6,496
    9,760
    4H0 943 021
    4H0 943 022​
    From the link in post #1 it looks like you need one of each of the above otherwise with two the same one will be shining on the plate and the other facing opposite.
  32. mike foster
    3,967
    You are referring to 4H0 943 021 & 022 which are only fitted on A5 cabr. 2012 onwards
    I am referring to 4G0 943 021 which fits both sides and is fitted on A1, A4, A5, A6, A7, Q3, TT, RS5, mainly 2010 onwards but some 2011, 2012 and 2013 onwards.
    I assume that the fitting is symetrical and can be fitted either way round.
  33. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,035
    741
    mike the - A1, A4, A5, A6, A7, Q3, TT, RS5 have a differant lamp unit to the A3's. i have been getting these ones for a while but they wont fit the A3/a5 cab/q7 as they are the ones that just clip off, no screws, they also require an adaptor loom which i also have.
    these ones are new to me but i have a feeling they wont work in the A3 8p3, i get the same problems on a a1 thats fitted with the halogen plate lamps, when you put the led bulb in an error is thrown up, same with the OEM audi units in the A1.
    As a few have mentioned it could be all down to some sort of coding.
  34. mike foster
    3,967
    Sorry mate - was originally responding to part numbers for A5 cabrio 2012 onwards which, according to post #13 fit the '06 sportback.
    Too confusing for me !!!
  35. t8ups
    2,035
    741
    oh right,
    the a5 cab have the same units as the A3 and will fit as they are the ones in the OP.
    the others listed use a differant type of holder and have been out for about a year now.
    i am sure they wont work in the 8p3 but i think its a case of waiting for someone to try, the canbus in the 2011+ a5 is not like the 8p3, i have sold many led bulbs to the cab owners and they work error free. its just the A3 and A1 that have problems.
  36. amar06fbr
    1,055
    68
    so we need the 4H for 8ps not 4G?
    ahhh Big plans? i still havent seen what you done to your car or it looks like, have you got a thread?
  37. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Haha got a lot planned for the interior my build thread is over on vagoc never really did one here how is your car getting on
  38. amar06fbr
    1,055
    68
  39. t8ups
    2,035
    741
    yes you will need the 4 h lamps.
  40. PH1L
    PH1L Gievf Buckets
    3,851
    40
    what are the differences in the a1 lamps anyone got a photo of em, i hate the design of the a3 ones, i have to seal mine with vaseline etc to stop any moisture getting in
    the link for vagoc is VAGOC.co.uk - The Volkswagen Audi Group Owners Club its mainly ttrs based but there is some good info on there, doesnt quite have the same knowlage base electronic wise as here but in terms of the powertrain a lot of stuff there s3 dan is on the jonnyc a lt of bigger engine builds
