Orange light on dash
AudiLad Feb 18, 2008
  1. AudiLad
    AudiLad Member
    145
    hey,i have an orange light that has come on,checked my manual it says its something to do with my emissions,its looks a bit like a tap and its orange,does anyone know wot it is and how to sort it? thanks
  2. JamS3
    JamS3 Active Member
    2,258
    20
    Could be a number of things mate only someone with a vagcom computer will be able to plug it in and read the fault code.
  3. AudiLad
    AudiLad Member
    145
    arite tar,ive got audi warranty on it,just wonderin if it was staright forward problem 1st
  4. MJZ 6370
    MJZ 6370 Member
    41
    Do you have a 170 TDI by any chance?
  5. AudiLad
    AudiLad Member
    145
    nope its a 140 mate,its a diesel tho,could this be something that effects the diesels?
  6. Issac Hunt
    1,162
    If its still under warranty then just get it back to Audi and tell them to fix it.
  7. AudiLad
    AudiLad Member
    145
    plan on,just thought it might have been a simple thing
  8. Issac Hunt
    1,162
    It probably is something simple but without a VAG-COM scan you have no way of knowing where the problem lies.
  9. bacardi
    bacardi Active Member
    1,139
    if it helps, this was apparently caused by a faulty throttle body with my A3, something made me a little suspicious though, maybe the fact the dealer had them in stock
  10. AudiLad
    AudiLad Member
    145
    ok thanks,well il take it in to audi and let them sort it out under warranty,but i shall let you know if it turns out to be a faulty throttle body or not
  11. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Not quite a throttle body I can't remember what the official name is.
    Beware though if it is you'll probably find that it has also taken out the fan controller fuse.
    Yes it is a common fault, the Audi Assist guy had one on the van and fixed mine at home.
    Paul
  12. AudiLad
    AudiLad Member
    145
    no probelms with my fan mate,so possibly wont be that then
