Optical Parking System Mod Installed
NHN Aug 6, 2010
  1. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    I've got my cat now and I have this controller -
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 G HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0120
    Revision: 11001001
    Coding: 000103
    Shop #: WSC 06314 000 00000
    VCID: 4280C0B564E4
    Which as you can see is a 4 sensor but VCDS didn't seem to have any more coding info. I'll have to see what Ross Tech know about it.
  2. kkp0897
    kkp0897 Active Member
    768
    45
    Cheers Stu, I see you have repeatedly questioned what Parking Controller others have, lol.
    No idea what I have but following my visit to Gareth's hopefully i'll be able to shed some more light on the subject.
    Will keep you posted.
    KKP
  3. VRStu
    1,073
    Yeah, the reason I am interested is that so far as I know Optical is only offered with an 8 sensor setup and I only have rears. I don't really want the hassle of adding the fronts so I'm interested to know if the 4 sensor can be made to work with Optical or Camera.
    i've asked RT so I'll let you know.
  4. kkp0897
    768
    45
  5. VRStu
    1,073
    Thanks KKP. I had read that and hence my trying to get to the bottom of what works. I looking for something like this but for the 8P units -
  6. NHN
    29,352
    1,720
    Have a look at 8P 2011 in ETKA page 919-20 it shows part numbers & the order codes to the right next to them thats shown in the brochure, this will enable you to work out which module does what.
    But, it also shows the D module as 7X2 compatible, so this will do OPS aswell IMHO, whether or not this is Front & Rear aswell, as I seem to recall this was maybe an older module with rear only, but need to confirm with others on here if they have this module.
    I have the H module & the sensors 4H0919275A all round as per ETKA.
    As per Stu has said, but you also will need possibly to rewire the BUS to the drivetrain instead of convenience along with possibly upgrading your gateway to suit, as module 10 wasnt available on older gateway modules, I now have the latest AD version which supports all latest modules.
    I have fitted front & rear system as thats the only system that seems to support OPS (subject to checks of the D module) if you look at the 8P latest brochure, shows 7X2 as the order code for that system.
    Re: RT, same position as always, emails sent but no replies, but see him replying to threads that have been resolved way before his input.
    That would depend on your pdc module fitted & possibly the sensors aswell, if this is the auto steering you have, then it may clash, TBC.
    When I've 100% finished fitting yes mate :)
    Well latest version is 8P1862335, wonder what this has added as its from 5/10.
    I only know that the D & H module will do OPS & the H is Front & Rear only, as if I have front disconnected it wont work at all, just beep once to signify a fault, when fronts are in then will work fine.
    Must be a way to trick the pdc module into thinking the fronts are working ok & no obstacles.
    Was that 7P6 on a VW?
    Yes for the camera system they're using the R8 module but this isnt OPS like this system, it was a camera feed with lines.
    If you want both then a VW car would be needed as not seen an Audi with the system like VW's have.
    My 1st thought is dont goto Gareth.
    Well unless you have scanned the car to see what faults are there & modules installed for the pdc, then cant really be specific, but sounds like needs coding properly as it wont just work out of the box, rns has to be coded for this to work & may take few hours to take hold as mine did, about 4-5 hours to be exact for modules to recognise system.
    PDC Plus doesnt neccessarily mean yours is compat, you need to check the pdc module fitted & wiring may need changing.
    G module is the 7X1 order code & isnt OPS, you'll need to upgrade IMHO.
    Well I have repeatedly emailed & msn'd someone, but I also got no reply, maybe some who are asking for advice & help should bare this in mind next time when they are asking for advice/info IMHO!!!!!
    If we can check the D pdc module then this may answer your query.
    As above.
  7. kkp0897
    768
    45
    Well, not taking anything away from Nigel as the gotta give him a big thanks for giving me the inspiration and information for me to get it done too.
    I did take it to Gareth, he's has always helped out with any queries I've had and sorted out the coding for me which as it happened Nigel was the same as you highlighted above:
    0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
    • 2 = Optical Parking System????
    No additional wiring, no additional modules. Near enough plug and play.
    A couple of pics... (haven't pushed the unit in as yet as I want to explor\investigate Digital TV and Multi DVD Player. Apologies for Pic quality but you can blame the iphone for that..!
    Stu - Why not 'suck it and see' nothing to lose.
    If anyone knows where the module lives, happy to take a look at model number etc.
    KKP
  8. NHN
    29,352
    1,720
    Just use vagcom to check module version.
  9. kkp0897
    768
    45
    Something I dont have (yet) hence going to Gareth. Going to invest in the kit.
  10. NHN
    29,352
    1,720
    No disrespect mate, but you could of spent the dough on his time on buying vcds & then coded it yourself & had the cable still to use, PM me when you are interested in the investment, as this is a prime example of where it would be useful to have huh fella.
  11. kkp0897
    768
    45
    Non taken sir, you have PM...
  12. VRStu
    1,073
    Thanks for the replies guys.
    Nigel, I've been working away for quite some time with no access to MSN so you wouldn't have been able to get hold of me and I've not seen any email. Would have replied if I did.
    A bit more news from me. The most recent version of VCDS now has support for the 8P0 919 475 G. Looking at the coding page it offers both OPS and RVC. I tried to enable OPS but it won't take it however it will allow coding for RVC. This was also confirmed in a reply from Ross Tech. Clearly the proof would be in the pudding and trying the camera.
    So far as I am aware the new version of VCDS still doesn't have support for the new gloss framed RNS-E. My coding is 0209725 if that helps at all. Seems to tie in with what Nigel has above. I will try the change to OPS on the RNS-E and see what happens.
    I don't know that I am going to get OPS working with just the rear sensors I have so I think I will go down the RVC route. I'm going to spend some time today confirming the wiring for the RVC today but I think there is a loom on Kufatec that might just be suitable.
    Nigel there is a suitable RVC setup for the 8P that will give you the same results as the Mk5/6 VW ones you refer too.
  13. euroaddict
    euroaddict New Member
    I've read through this thread.. im i really want the parking to display on my 2011 rns-e (193f)..
    here's the thing i have the factory parking sensors that came with the car, , would i have to replace anything? or can i just vag to get the parking screen to show up? i know it wont show fronts (becuase i dont have them) but will it at-least show the rears? ..
    and if so.. can someone tell me exactly what needs to be coded in vag com?
  14. amran
    amran New Member
    Hello, I'm Italian and unfortunately I do not speak English well and I apologize for that;
    I have two months from a S-Tronic TTS facelift and I would turn on the OPS had RNS-E and 193D PARKING rear;
    -What should I do?
    -I will post the detailed encoding?
    PARKING will post my unit and I thank you very much and I apologize for the poor language!
    Address 10: Park/Steer Assist (J446) Labels: Redir Fail!
    Revision: 11001001 Serial number: 93631027821923
    Coding: 00010B
    Shop #: WSC 01236 758 00200
    No fault code found.
    Address 37: Navigation Labels: None
    Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
    Component: RNS-E PU EU H05 0200
    Revision: 0000011S Serial number: AUZBZ7KD400673
    Coding: 0609756
    Shop #: WSC 00000 141 61663
  15. NHN
    29,352
    1,720
    Where in Italy as I am in Venezia adesso.
  16. amran
    amran New Member
    I am in SICILIA-CATANIA!
    Do you speak Italian?
  17. NHN
    29,352
    1,720
    Poco, but this forum is English, so keep it that way per favore :)
  18. amran
    amran New Member
    Certainly, he is right!
    But it is clear what I wrote or do not understand what I ask?
  19. amran
    amran New Member
    You say you can enable TTS to my ops?
  20. amran
    amran New Member
    Friends, do not abandon this discussion, I need your help important!
    E 'OPS can turn on my car and what should I do?
  21. NHN
    29,352
    1,720
    It already states the setup, you need to try coding your rns for the system, if this doesnt work, then you'll need a different controller & front sensors.
  22. JohnS3
    JohnS3 Active Member
    3,032
    Nige, will it need the CAN to LIN rewire?
  23. NHN
    29,352
    1,720
    Depending on your year of car, it did change bus around 08, went from Convenience to Drivetrain, no LIN involvement iirc.
  24. JohnS3
    3,032
    Sorry, I meant drivetrain, short of coffee this morning.....
  25. NHN
    29,352
    1,720
    Dont worry I'm short on everything this morning for 1 motherfecker in particular, namely fuse & patients & that person isnt you mate :)
  26. amran
    amran New Member
    Damn, so if you do not change the form parking, I hope to be able to have this feature?
    And if I tried some coding?
  27. NHN
    29,352
    1,720
    I already said you need to test coding your rns & pdc
  28. amran
    amran New Member
    and what do I do to test it?
    If you do the screen obtained by VAG, not enough?
    Mine is a 193D!
  29. NHN
    29,352
    1,720
    Uh code the rns as I've now told you 3 times.
  30. tku
    tku Member
    630
    Can't you just pop to his house to explain this again?
  31. NHN
    29,352
    1,720
    Fill in the blanks "FUC_ OFF" :p
  32. 1animal1
    9,978
  33. Ads
    Ads License to drive
    8,230
    608
    Might take a while to find "Itay". Not many planes flying there, I bet.
  34. amran
    amran New Member
    how to test the code RNS-E to verify the operation OPS?
    Coding: 00010B
    Coding: 0609756
  35. NHN
    29,352
    1,720
    READ THE THREAD as above.
  36. amran
    amran New Member
    Ok, already tried it but it does not work!
    It may be that more needs to be activated?
  37. Reedswood
    Reedswood Guest
  38. NHN
    29,352
    1,720
    Reeds, which version are you looking for?
  39. NHN
    29,352
    1,720
    No you havnt cause your coding still shows 0 not 2!!!!
  40. amran
    amran New Member
    I have tried is to put 2 instead of 0 in the right position and I also tried:
    connec t the VAGCOM tool. select parking system / after 07 (code) I replace the second bit (from the left) by 2 (before 0).
    But it still does not work!
    How do I know if the active function '
    Just shift into reverse and is the chart or something I have to first set up SETUP?
    I brought the code above, dates back to before you try!
