Opions on Eibach and H&R lowering springs for s-line
afcjay Jul 2, 2011
  1. afcjay
    afcjay Member
    437
    Ive know its been discussed before (i have read a few older posts) but now people who have lowerd just on springs i wondered what there thoughts were
    Im thinking about lowering my tdi s line in the future and wondered which springs people would recommend with s line shocks (eibach,h&r or other)
    I would like it lower than standard but would like to avoid a harsh bouncy ride and i also have quite a few speed bumps in my area,so cant be to low and dont really want coilovers
    Also if anyone has any recent pics of either eibach or h&r springs fitted along with the details of the drop (mm) that would be great and at the same time what size wheel spacers would be best to use with the standard 18" alloys for the time being
    Thanks in advance
  2. Farhan
    Farhan Active Member
    1,234
    58
    Is your car FWD? see the thing is my friend has a R32 which uses the 4WD system. Hes now lowered on springs and in terms of ride quality you cannot notice any difference. Im really fussy with a horrible bumpy ride so i havent lowered the car yet but i to would like opinions from owners who have lowered there FWD cars.
    The 4wd systems weigh the car down a fair bit so the added weight makes the cars quite smooth compared to the FWD cars which are light but tend to be more bumpy!
  3. afcjay
    afcjay Member
    437
    Hi there,yes mines fwd
  4. DPM
    DPM Site Sponsor Site Sponsor
    5,065
    224
  5. Ads
    Ads License to drive
    8,230
    612
  6. DPM
    5,065
    224
    It's always best to change the dampers to match the springs but with you having the Sport dampers you should get a few more miles out of them with the H&R's on.
    Damian @ DPM Performance
  7. Adam.
    Adam. Meow.
    662
    34
    Anyone got any pictures of these fitted?
  8. v1raj
    v1raj Member
    308
    20
    Im running 50mm H&R's, purchased from DPM, on my A3 3door Sline.
    Would recommend them :) But then again, i haven't been in an Eibach A3 to compare.
  9. Farhan
    1,234
    58
    Pics bro!!
  10. v1raj
    v1raj Member
    308
    20
  11. afcjay
    afcjay Member
    437
    ive read somewhere the eibachs sit lower on the rear than the front,is this true if so think ill be looking at the H&Rs
    Also does anyone else have any pics and details of the drop height
  12. Ads
    8,230
    612
    I thought it was the other way around.... they lower more at the front than the rear.
    I always think that A3's seem lower at the front as standard, so the fact that eibach lowers the front even more than the rear sounds not that good to me.
  13. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,416
    516
    I would always recommend H&R's as a preference over Eibach, not that there is anything wrong with the Eibach's as my friend has them on his 3.2 sport, but I just think they are a more developed spring. I took a photo of the H&R's and Eibach's together when we put them on and you can see that the H&R's have a progressive spring
    H&R's on the right
    Here's a pic of my S-line sportback with the H&R's fitted
  14. andi1
    andi1 WWW.APR-REMAPS.CO.UK
    220
    Are they the 50mm or 35mm h&r`s?
    18" or 19" rims?
    thanks
  15. afcjay
    afcjay Member
    437
    Im liking the stance.Any problem with speed bumps?
    Anyone got pics of eibach springs fitted?
  16. N8
    17,163
    720
    They are 19" BBS CKs
  17. -Ju-
    2,416
    516
    No problems with speed humps but obviously you can't just fly over them, the wheels are also a 44 offset i.e. 10mm nearer the arch and don't rub at all.
    AFAIK they are 35mm springs as that is the only option listed for the 3.2. It was about 30mm ish from S-Line height that it dropped. As for the wheels, they are 19's
  18. afcjay
    afcjay Member
    437
    can you also tell me if the pic was taken straight after fitting or when they had settled as they normally drop a little more once they have settled?
    I really wouldnt want to go much lower than that due to the amount of speed bumps in my area
  19. -Ju-
    2,416
    516
    Yeah was more or less soon after fitting
  20. afcjay
    afcjay Member
    437
    Have they dropped much more since?
  21. N8
    17,163
    720
    H&Rs are usually a little stiffer iirc than eibachs...
  22. -Ju-
    2,416
    516
    Not that I can tell, been on 18 months now:thumbsup:
  23. afcjay
    afcjay Member
    437
    Is the ride better than the s line springs? they arnt to bouncy/hard are they?
  24. N8
    17,163
    720
    Your not really gonna notice a massive difference.
  25. -Ju-
    2,416
    516
    I think you'll find that the ride is better than oem, a little softer feeling but firm enough. I had them on my old A3 and it was the first thing I bought for my current one
  26. afcjay
    afcjay Member
    437
    thanks for the replys people just need some feedback/pics on the eibachs but am swaying towards the h&rs
  27. rockape
    rockape Per ardua
    283
