Opinions-carbon bonnet
stapo69 Jul 24, 2008
  1. stapo69
    stapo69 All hail the mighty quattro!
    969
    Thinking ahead, just thought i'd see what folks thought.
    Found this pic of a carbon bonnet with painted outer edges.
    Not liking the painted grill, thinking leaving the standard silver, or maybe satin black? But do like the painted outer edges along the original bonnet lines.
    I have the RS4 front bumper on the way. Also I have the RS4 grill already, along with carbon mirror caps and b-pillars fitted so thinking this may be next on the list?
    What do you guys think? :uhm:
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Well, stealth would be straight out the window!
  3. Siena
    Siena Active Member
    2,626
    I like it, but don't like bonnet pins, which CF bonnets need.
  4. Siena
    Siena Active Member
    2,626
    Then there's also the issue of UV damage over time.
    B-pillar and mirror caps are ok.
    But a bonnet, being such a large area, and horizontal to the sun, it'll go brown in time.
  5. Fraser
    Fraser Member
    584
    i don't really dig the carbon bonnet thing
    i much prefer noggy blue...
  6. stapo69
    969
    I had read that they can change colour over time, Seibon are supposed to be a good make that coat theirs with UV reflective coating, supposedly reducing the fade over time, but still inevitable over time i guess. Needs to be kept well clean and looked after too. Pray for good old **** British weather!
    And again I'm with you on bonnet pins, doesn't seem to be much of a way around it, even with the standard bonnet latch being used, the corners lift, even though you'd think it'd be stronger! There is the option of some decent quality flush fitting items, but still spoil the lines a wee bit.
    Hmmmmmm
  7. ALPINE
    3,093
    <<<< goes looking for a standerd RS4 bonnet.:undwech:
    mine needs spraying any ways so i mite as well spray a beefy 1!!
  8. docurley
    4,073
    88
    The RS4 bonnet is the same as the A4's no difference at all and no they are not made of ally as some people thought.
    I like it but as stated you will need bonnet pin's I dont like them hence why I have never gone down this route. As for going brown if it does just paint the whole thing Noggy job done oh and the heat of the enginee will help turn it brown too.
  9. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    looks excellent and I like the sprayed edges, but I agree pins and colour coded grill spoil the look
  10. g60leigh
    1,674
    207
    wonder if there would be a way of using bonded metal plates on the under side and magnetic lock, probably something similar to those used on fire doors so with electric switches, that way they can be on when running to keep bonnet down tight and off when engine off to save power and not be needed then as the standard bonnet catch keeps it locked??
  11. Z82
    Z82 Member
    454
    Not a bad idea that and you can get them in 12v DC
  12. andybnwc
    andybnwc Member
    752
    Colour coded aero catches dont look too bad , got a friend with a R33 with them , they was carbon to match bonnet then painted bonnet and colour coded , you can hardly notice them..... well alot less anyway
  13. Bushen
    Bushen Driving with style
    52
    Defo like the look..:footy:
  14. ALPINE
    3,093
    oh...
    i thought they were made of ali. i learn yet another b5 fact!
    :thumbsup:
  15. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Counts me as well I always thought the bonnet was aluminium. Better touch in those two stone chips then
  16. Road Razor
    Road Razor Member
    411
    I prefer it fully painted in noggy blue. I don't like the bonnet pins either but one company states that their A4 bonnet come with OEM latch. How effective they are I don't know.
  17. two words: why bother?
  18. Sorry, a bit harsh, but what does a carbon fibre bonnet bring to the party?
  19. aragorn
    18,609
    871
    less weight over the nose i presume is the main benefit
  20. But how much weight? Sod all compared to the overall weight, I bet.
  21. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    i like it.i think the main reason for doing it is that the carbon looks nice.carbon pannels and doors would be nice so inconsiderate **** holes dont dent the sides of the car as well.
  22. Phantom_A4
    Phantom_A4 Member
    563
    Seibon do make bonnets that use the original latch, and don't require bonnet pins, just like the picture above. Personally if i was going to buy a carbon bonnet i would leave some area uncovered, and i like the way he's done this on the pic. The only major difference is weight, but cosmetic looks as well....Why do people change most things on the car? Mostly cosmetic looks, like the rs4 grille etc.....does nothing extra but looks better!
  23. Siena
    Siena Active Member
    2,626
    Phantom, a guy over on Audi World bought a CF bonnet, that the manufacturer's claimed had a reinforced section to fit the factory pin / catch to.
    Said it didn't need aftermarket pins.
    The bonnet burst oped at speed, and the guy spent time in hospital, as his screen broke too, and his face was a mess! (Both airbags went off).
    Do a search on there, there are pictures of the damage - both to the car, as well as his face.
    I wouldn't trust a CF without aftermarket pins, and as I don't like the pin-look, I'd pass.
    I had a similar scenario back in 2001 - my Sport Quattro fibreglass bonnet (part of the Rieger GTO Competition kit on my RS2-engined B2 Coupe Quattro blew off on the A2.
    Luckily, my damage was limited to my roof and scuttle, my screen and face were fine.
    Just food for thought.
  24. billybravo
    billybravo Active Member
    1,045
    well ive had my carbon bonnet now for around a year without using bonnet pins, and is fully secure i do check every so often for stress and cracks
    the bonnet i use is a fiber images from the states
    my bonnet is fully carbon and not a two peace like sebon which uses a glassfiber frame and carbon top skin.
    As long as the clear coat has a UV protector its unlikey that the bonnet will go brown, its a clear coat just like on your own cars paint work.
  25. stapo69
    969
    Billybravo, can you get hold of these bonnets? What sort of price would I be looking at?
  26. Mithdons
    Mithdons New Member
    26
    It looks awesome, i think theyve done it jsut right not too in your face but will get ppl wondering.
  27. jcb
    jcb Active Member
    4,132
    13
    if I was going to do that I would go for a whole composite lift off front end for strength and weight.
    I am not going on a diet anytime soon and they are waaaay pricey for a decent one (and by that I mean one with UV block finish and original latch fitting.
    I looked at a kevlar front end for my Mk2 golf when I was going all anorexic track day beast...costly and gettting a decent fit was an issue
  28. stapo69
    969
    Seibon do them with a good UV protection and use of the original bonnet latch too. But as pointed out earlier, is it worth trusting just that? In a car that'll do easily 150+, no that I drive at that speed of course......
    The best option I've found for bonnet pins/catches are these, nice and flush and can easily be colour coded. They do ones that mount from the top, and ones that mount from underneath, which would look great if there was a way of fitting them without having the bolts coming through the bonnet, and leaving just the latches. But I can't think how it could be done, except bonding them on from underneath, but I can't see that being strong enough?
    http://www.aerocatch.com/
