Open door indicator won't turn off?!
JCC1981 Oct 27, 2005
  1. JCC1981
    JCC1981 Member
    54
    Just got in my car at lunch and my drivers side door indicator won't turn off, it says the door is open when its closed?!!?
    anyone had this problem aswell? any idea how to fix it?
    Thanks,
    JC
  2. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    I occassionally have this problem... more in the summer time when it's warm outside. I think it is a common problem.
  3. madvw
    madvw Active Member
    2,489
    door sensor, faulty microswitch, needs new door latch mechanism.
    A common fault.
    Heavily documented already on the forum. Use search.
  4. make this a sticky mods! please.
  5. god_thats_quick
    2,507
    or add one of the other more informative posts to the FAQ... which would probably make more sense /ubbthreads/images/graemlins/noidea.gif
  6. Defratos
    Defratos You’re Dethpicable!!
    2,232
    got the same god damn problem today, I've had it like 50 times already /ubbthreads/images/graemlins/burningmad.gif /ubbthreads/images/graemlins/burningmad.gif
  7. god_thats_quick
    2,507
    £40 and some effort and it's solved... for me anyway
  8. Grant
    1,206
    118
    Can anyone list the part number of the part required? Even better, can someone was has rectified this problem right a "DIY How To..."?
  9. god_thats_quick
    2,507
  10. MickA3
    MickA3 Member
    98
    I had the same problem with my drivers side door and decided to sort it out over the weekend- got the door lock for 62.60 + VAT (Euro) from Audi and borrowed a friends garage....it took about 2-3 hours and was easy enough to do although there were a few heart in mouth moments when i wondered if i'd gone too far....i took some photos along the way which i will post soon....basically i went about it like this- I put window fully down, then i took off door card (screw on top left and right of door and two behind handle grab (remove screw to see these)- then lifted door card upwards and off the door- then disconnected all the electrics (block connectors- some stubborn!)...then undid four big hex bolts on subframe (at this stage as someone suggested previously I noted the position of the spacers at the hex bolts) and once all the bolts were off I swung the door frame (which includes window frame and mirror) away from the door....then I removed a plastic shield in front of the lock and disconnected rods, electrics, door pin at lock unit and undid two smaller hex bolts to free the lock assembly (these bolts are located at side of door- visible when door open)....switched the door lock and put it all back together....door lined up perfectly and everything is working as new....(I'm not saying this is the way to go about this job- there may well be an easier way but the method described above worked for me and it wasn't hard to do!)....
  11. Khufu
    Khufu Well-Known Member
    5,704
    31
    Sounds like the way I did it on mine. As you say, the alum wedges look like they need to be marked for location but they are crushed/marked anyway so its not too hard to reposition them correctly. Looks worse a job than it really is.
  12. god_thats_quick
    2,507
    That's how I did it other than I left the window all the way up and once the window and frame was seperated from the door shell I taped it into the closed position (worked a treat) what did you guys do about the frame etc once seperated?
  13. MickA3
    MickA3 Member
    98
    I just swung the frame into the 'closed door' position and rested it on a cardboard box which was just the right height to ensure no pull on wires entering the door frame from the door hinge area....and then left the door itself in the 'door open' position in order to get at the lock....
  14. necroeire
    necroeire Active Member
    1,008
    MikeA3, hey mate can you post some pics as I will be doing this soon, I've had two flat batteries from the door sensor thinking the door is open and it is beginning to upset me. If I slam the door a bit it seems to work but I'm taking the plunge and sorting it once and for all (I hope).
  15. Khufu
    5,704
    31
  16. MickA3
    MickA3 Member
    98
    NecroEire- No bother!....i'll try get them posted over the weekend
  17. MickA3
    MickA3 Member
    98
  18. Khufu
    5,704
    31
    looks like your doors have some extra protection than my older style.
