Only getting 20/21 MPG on my 3.0! help!
drewbee Feb 17, 2010
  1. drewbee
    drewbee Member
    196
    hi guys, as per title, im getting really poor fuel consumption,
    according to parkers, it should get 28MPG.... but im struggling!
    what are other 3.0 v6 owners geting?
    your info is much appriciated.
    Drew
  2. Nutkin
    Nutkin Member
    830
    If that were me, give her a service etc new filters and the such just a genral flush out etc see from there.
    Another option is MAF sensor always improves a lil with any vag engine.
    Tyres inflated and even now design can help with fuel :) so if you are running budgets that could be a lil saver.
    Also driving style :p but i assume your doing that one yourself to find out. Ive only driven the 3.2 as a run about when i got rid of the corsa and best i could do was 26 or so .
  3. drewbee
    drewbee Member
    196
    thx for ur reply, ive had a full service few weeks ago n im running avon tyres which are 2 months old. done a vag com scan and nothing came up.
    could it be d fuel filter? as this wasn't changed at service.
    driving style is normal, can't even step on it in fear of visiting d petrol station again. lol.
    help!!!!!
  4. stoakseya4
    stoakseya4 Active Member
    1,221
    TBH the V6 is a rubbish engine (NA) in terms of fuel consumption. Not much better than the V8 in fact.
    You're never gonna be geting 28mpg other than a long m/way journey at 70mph.
    20-21 isn't far off the mark I'd say...
  5. no_idea
    no_idea Member
    170
    Mileage wise I get about 23-24 mpg on my work route, which is about 12 miles of 'B' roads.
    On a motorway run so long as you sit at about 70-80 mph it will give 28-29 mpg. Some people can get over 30 mpg, so they say, but I think you would have to drive with economy in mind. I have never got over 30 mpg.
    Doesn't the multi-tronic make a difference to, if so I would agree with stoaksey it wouldn't sound far out.
  6. Nutkin
    Nutkin Member
    830
    maybe try a different maf then but see what is actually changed in your service cause the horrors i found when doing my car, original spark plugs. Ive seen smaller gaps in the grand canyon!
  7. swarcup
    swarcup Well-Known Member
    1,326
    40
    HAD A GO IN MY UNCLES 3.0 QUATTRO LE-MANS EDITION ON THE WEEKEND AND HIS DIS WAS SAYING 34MPG (06 PLATE)
  8. BillTheButcher
    BillTheButcher Member Audi RS3
    170
    24
    :faint: Bloody hell. That's impressive.
  9. hooley
    hooley Member
    199
    It is a diesel though......
  10. BillTheButcher
    170
    24
    Is it? Ah. Didn't realise that. In that case 34 MPG is rubbish. :happy:
  11. aragorn
    18,032
    722
    does it come up to temperature properly?
    Ie 90c after a few miles and then stay there?
    Also depends where your driving it, you havent said.
    If its all around town, stop start 30mph type driving, thats all your going to manage. if your only getting 20mpg on a run down some a-roads sitting at a constant 60ish then theres something wrong with it.
    End of the day, its a heavy car, with a large engine, i'm not really sure how much better you were expecting...
  12. niftyandy
    niftyandy Member
    100
    I agree with stoaksey, about right really, though these figures you mention are figures I'm getting for a remapped 3.0 so i'd assume a standard one (if it is) would be about 5-10% better!. I've heard good stories about fuel filters being replace, helping performance and mpg, so worth a go at the very least i'd say. Try using high octane fuel for a few fill ups too...V power should clean your engine over 1000 miles or so, you then might see a difference. Don't panic!
  13. rjm180
    rjm180 Active Member
    581
    34
    Drew
    I had an 05 3.0 cab multi until last week which used to display about 19-21 around town and about 28-30 on the motorway.
  14. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,382
    111
    im getting about the same figures and mines the 1.8T i dont get anywhere near what people report ! i know cabs are heavier but even trying really hard i cant get 30mpg
  15. Quattro180
    Quattro180 Member
    99
    I dont know if this helps, but i have 2.5 tdi (180) tiptronic. A full tank only does 300 miles. I am not sure if there is a problem as i have nothing to compare it with. I am having a vag com scan this weekend.
  16. The Slug
    The Slug Active Member
    1,869
    blimmey my S6 is economical at 22/3 mpg average......you must have problem somewhere!
  17. quattrojames
    14,050
    574
    Damn, that must be a thirsty gearbox! I get 450 on average from my manual....
  18. markyzs180
    markyzs180 Member
    543
    I only get 25 out of my 2.5 tdi around town drew....
  19. Quattro180
    Quattro180 Member
    99
    I must have a problem somewhere, it doesnt like starting from cold either, it doesnt fire on all cylinders for a few seconds afer it fires up? the turbo also whistle more than i think it should?
  20. quattrojames
    14,050
    574
    Mine does the very same, you got any ideas?
  21. Quattro180
    Quattro180 Member
    99
    I am thinking maybe glow plugs or fuel pump timing? Fuel pump timing may also indicate why my fuel consuption is bad? hopefully find out on saturday!!
  22. quattrojames
    14,050
    574
    I've done my glow plugs, pump timing is next on the list. I'd be interested to hear how you get on.
  23. Quattro180
    Quattro180 Member
    99
    I will let you know on saturday mate
  24. drewbee
    drewbee Member
    196
    Hi mate,
    i recently had the temp sender replaced, and now it sits bang on 90degrees so cant be that.
    im driving with economy in mind, no more more than 1500/2000ish rpm! it is used only around town and hardly on motorways.
    sounds like no matter how i drive it, im only gona get 20mpg.
  25. drewbee
    drewbee Member
    196
    i was thinking about the fuel filter.... might get that replaced.
    any ideas how much 1 costs?
  26. drewbee
    drewbee Member
    196
    hey Mark, that sounds **** esp when yours is a diesel!!
  27. drewbee
    drewbee Member
    196
    anyways, im getting my mechanic to have a look at this at the weekend.
    he said something about hooking it up to a computer, taking it for a drive and mesure the actual air flow or something like that and comparing it to what iit should produce - something along them lines and with that he would be able to work out what may be causing the poor fuel consumption.
  28. polar
    polar Member
    86
    I only get 22-25 MPG around town. In the morning with part A roads and Motorway I get 29 MPG. On one long journey (300 Miles, motorway and A roads) I managed to get 32 MPG.
    I did turn on ECO mode on my aircon and get 2 MPG extra.
  29. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,116
    2,571
    Drewbee, your fuel consumption isn't poor; it's about right for the type of driving you have described. The only time you'll see high twenties/early thirties is on a steady motorway cruise at 70mph.
  30. dans3.0
    dans3.0 Member
    56
    drewbee
    Sounds about right mate,
    Its a heavy car with a fairly large engine,
    mine does the same, only really use it for shorts trips during the winter to and from work etc,
    Best I ever got was 430 miles on a full tank mostly motorway with cruise set at 80, normally only get around 270 to 330 on a full tank depending on the type of miles i,ve done, had the car from nearly new and its never been any better its now done 60k has a FASH and i generally use tesco 99 super unleaded.
    Although I dont really drive with economy in mind:eyebrows:.
    Dan
