One week in and the first quirk has arrived (PDC / VCDS issues)
warren_S5 Nov 9, 2011
  1. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    I knew it couldn't last forever, a week and a day into ownership and we've had our first car glitch.
    Yesterday I plugged in VCDS to have a look at whether there was any fault codes after a week of running. There was one intermittent error on the boot light which when cleared did not come back?????
    I looked through the options menus for anything trick, and decided to set up:
    1) Teardrop rear wiper active
    2) Syncronized mirror adjustment
    3) Checked Nav coding and saw the setting for speaker test was set to Option 2, but only option 0 and 1 is listed in VCDS menu, so I set it to one (speaker test off)
    4) Alarm beeps on/off with central locking activation / de-activation (nice subtle beep on this car, not loud chips like on my 8P2).
    Accepted changes and all was good
    Went to park in the garage last night, and the Park Distance Control (PDC) screen didn't come up on NavPlus screen. I thought it seemed strange, so I recycled ignition, tried again, and nothing.
    So I went back and got VCDS cable, plugged it in, and changed all the settings back to what they were yesterday (e.g factory), and then tried again. Still no PDC screen. Took keys out, rebooted laptop, installed cable again, checked for error codes - nothing. Tried PDC again, and it worked?!?!?!!?!? (Screen is back as normal).
    As I went to lock the car and get something from the house the car beeped as I locked it (I'd turned this off earlier so thought it seemed a bit odd). So I come back ut to car, go to open 09- Cent. Elect. under installed items and the search timed out. Said it could not access this menu item. So I run error code check again, and even in diagnostics checking mode it cant open 09. Cent Elect. or 46. Central Conv.?????/
    It opened them OK yesterday so I don't get why it can't open it now?
    Good news is PDC screen info is back on RNSe, but I now have chirps when locking, but not when closing, and only knows what else. Been using VCDS for 2 years now so I'm pretty comfortable with using it, so am wondering if this is down to (1) me, (2) newness of car and updates by VCDS need to filter through, (3) something else.
    Any ideas?
    I'm running a NHN VCDS HEX-USB+CAN cable with VCDS Release 10.6.5 (latest version according to their site)
    Here is a copy of the Auto-Scan I ran on the car this morning (Issues highlighted in RED text):
    Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH20--- Serial number: - - - - - - - - - - -
    Coding: 0103000C180F0160
    Shop #: WSC 06314 000 00000
    VCID: 800B6EEDAA98
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 16428012092800FD680D01E5901900813E0400
    VCID: 7BF19901437E
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
    Component: KlimavollautomatH09 0180
    Revision: 000222 Serial number: 8P0820043BN
    Shop #: WSC 00000 000 00000
    VCID: 79FD83094942
    Address 09: Cent. Elect.
    Cannot be reached
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
    Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
    Component: PARKHILFE 8K H01 0140
    Revision: 11001001 Serial number: 12561126300609
    Coding: 100009
    VCID: 499D33C95922
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H09 0250
    Revision: -------- Serial number: 003JU0040YSW
    Coding: 303142413039303030384A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52AF14A5B474
    Driver's Airbag Crash Sensor:
    Serial number: 34928RB40000641CC7F$
    Passenger Side Airbag Crash Sensor:
    Serial number: 35028RB40000641CDE0O
    Driver's Rear Airbag Crash Sensor:
    Serial number: 35128RB40000641CCED.
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 35228RB40000641CDF3U
    Driver's Front Airbag Crash Sensor:
    Serial number: 35547RB40000666423FM
    Passenger's Front Airbag Crash Sensor:
    Serial number: 35647RB4000066641D4L
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0004042
    VCID: 468738F5483C
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 983 A HW: 8P0 920 983 A
    Component: KOMBIINSTR. VDO H02 0150
    Revision: D0H02002 Serial number: 2248K002000401
    Coding: 0277428
    Shop #: WSC 00378 210 92239
    VCID: 387B460D32C8
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 280811F1001201
    Coding: 350101
    VCID: 35654F3925DA
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
    Component: Haldex 4Motion 3018
    Coding: 0000005
    VCID: 45853FF9753A
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H02002 Serial number: AUX7Z0K8FNS089
    VCID: 387B460D32C8
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8P0 035 785 HW: 8P0 035 785
    Component: SG ext.Player H08 0100
    Revision: 00000000
    Coding: 020202
    VCID: F4E3323DEE20
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7LD217927
    Coding: 0229725
    VCID: 3463723D2EA0
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
    Component: Tuer-SG H04 0101
    Coding: 0004732
    VCID: 489B36CD4228
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 234 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3463723D2EA0
    Address 46: Central Conv.
    Cannot be reached
    Address 4C: Tire Pressure II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
    Coding: 0004732
    VCID: 499D33C95922
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P3 907 357 B
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000013
    VCID: 3C735A1D06F0
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0229725
    VCID: 3463723D2EA0
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005445380
    Coding: 0011422
    VCID: 35654F3925DA
    End ---------------------------------------------------------------------
  2. Ash187
    7,489
    742
    how have you managed to lock your self out??
    i have heard that disconnecting the battery for about 10 minutes (maybe more) and then connecting it back will reset the module to allow you back in... heard that from the horses mouth (sorry nigel :p)
    its not the first time i have heard someone to lock themselves out of the newer cars? maybe Ross-tech need to update the cables?
  3. warren_S5
    7,210
    2,486
    I've sent an email to RossTech asking them about it and given them a copy of what I've put in here.
    Does seem very strange, and it's something I've never managed to do in the 8p2.
    Does concenr me that there are values pre-programmed into the car (like the nav code for speaker diagnostics set to 2), whereas VCDS only shows values in the long coding for 0 or 1????
    I appreciate it's a game of constant evolution, so may need to wait for a Rosstech update, but in the meantime I'll try the battery disconnect trick!
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    Isn't the CE modue & the Convenice module now combine on the 8P3? That may be why they are red?
  5. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Sorry to hear you're having these probs, Warren :(. The Central Electric module is now 09 and 46 isn't used anymore in the 8P3. I had the exact same problem with my cable not being able to communicate with the Central Electrics controller 09, until I found out that I had to lock and unlock my car directly before I did any scans. It won't time out and should communicate if you lock/unlock immediately before scanning :wub: xx
  6. warren_S5
    7,210
    2,486
    Paullie, you are a star, I will go and try it this afternoon. :respekt: :kiss:
  7. Paullie
    2,076
    288
    You're very very welcome, Warren. :wub: xx
  8. warren_S5
    7,210
    2,486
    :sob:
    Nope, didn't work for me so I've gone and disconnected the battery (despite the manual telling me specifically not to!).
    Left it disconnected for 10 mins, reconnected it, and now I have a 'Stabilisation' issue, refer to owners manual!
    I've had to put VCDS laptop on charge so will try again later; nothing easy in this world!!
  9. Ash187
    7,489
    742
    i have seen this before where the car is configured with an option that doesnt make sense but from what i have seen is usually a tag that ross tech are not aware of hence vcds not being able to tell you what it is.
  10. lil_coz
    lil_coz Active Member
    1,641
    19
    Not issues already?! You had it sorted yet? What if you take it into Audi? Surely they should sort out the problems you've having on a 2 week old car?
  11. warren_S5
    7,210
    2,486
    Just got a response from Rosstech today:
    Next, were your car's doors all unlocked when scanning? The 09 module will not talk with doors locked, so it's worth trying to lock and unlock the doors before scanning. If that doesn't do the trick, you may want to try doing a cold boot on the car by disconnecting both cables from the car's battery and touching the cables together (AWAY from the battery of
    course) to get rid of any capacitive charge. Then reconnect them, make sure all doors are unlocked and try connecting to 09 again.
    Also, I'd recommend using Beta 11.10 which contains the latest label file and support the newest cars like yours:
    Ross-Tech: VAG-COM: Current Beta
    Locking and unlocking the doors made no odds to my car, and I haven't tried the car again since disconnecting battery but will try again this weekend. Problem I have is the doors chirp when you open it, and as I can't open Cent. Conv I can't turn it off, hence Audi will know I've been fiddling!
    I've sent them the initial log file today to review.
    Any more news I'll feedback.
  12. lil_coz
    1,641
    19
    Ah... the only reason I have't got VAGCOM or VCDS (guessing it's the same thing? :uhm:), is it's way to complicated for me!
    You see this to me is hyroglifics!! lol
    Hope you get it sorted soon bud.
  13. warren_S5
    7,210
    2,486
    Cheers Coss, no big issues as screen has come back, but RossTech are usully fantastic so I know they'll get everything sorted soon, I think it's a newness issue!
  14. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3
    5,196
    145
    Cant offerr much Warren except that on a full scan i dont have a 46 position at all. Mine goes 42-44-52.
  15. warren_S5
    7,210
    2,486
    Interesting, maybe when I do the update it will become invisible?
  16. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    No such probs on my BMW diesel:undwech:
  17. warren_S5
    7,210
    2,486
    Now if you had the new 1 series hatch, I'd disagree, but as its a 3'er I'll let you have that !
  18. Virdee
    Virdee Active Member
    172
    25
    I'll be watching this topic closely as want to carry out these touches to my new S3 SB BE.
    Did the teardrop work ok? And is front already configured?
    And also whilst we're on this subject - I was going to code my RNS-E for S3 startup screen, but upon collection noted it was already active. Can you comment warren?
  19. warren_S5
    7,210
    2,486
    Teardrop did work, as did chirps, but had to go and reverse them to get the PDC screen back. Synchronised mirrors was very useful for parking in bays.
    Hopefully as VCDS evolves it will all come good.
  20. Virdee
    172
    25
    Yeah got PDC screen on mine - so no messing for now.....
  21. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    He He, how do you reverse a `dislike`. Had a Stella keyboard mo.
    Talking of reverse, I have reverse sensors too.
    And an Automatic tow bar.
    Jus no fun :sob:
  22. NHN
    29,343
    1,719
    Start using beta 11 as your car may have the latest 063 CE board, hence why no comms, once using latest beta then try again.
    Alsooooooooooo, try going straight into module 09 instead of using autoscan option, so go into Select 1st, then 09 itself to see if you get comms direct.
  23. paddy
    5,196
    145
    He's da man :)
  24. warren_S5
    7,210
    2,486
    Where you been Nige, it feels like you've been missing for ages, had gone straight to RossTech thinking you were off on vacation!
    Great to see you back mate; hope all is well.
  25. NHN
    29,343
    1,719
    Ah mate number of things, 1 thing my gran again, yesterday went to see her to get her more positive on her feet for xmas as family over from Italy to see her xmas day so family gathering, she's in Bupa rest home recovering from op's & getting mobile again, so yesterday find she's getting nowhere, 20 min physio a week doing sweet fa, so decided I would cough up for private myself & making arrangements with my uncle etc, ring her later in evening to give her positive news about what we're gonna do as she's very down atm, only to hear her crying her eyes out in pain, the all I can say absolute cretin idiot thick headed staff, only earlier discussing said problem with her arm/shoulder, lifted her on her bad shoulder & broke it ffs, so she was carted of to hospital again.
    I mean seriously ffs, if you're told the area is unusable & extremely painful already, do you go lift that area anyway, I have many words I could use right now but it would end up as xxxxxxxxx & a ban lol.
  26. warren_S5
    7,210
    2,486
    Sorry to hear this Nige, fully understand where your coming from as my gran was in hospital last year with stroke and level of treatment she received was shocking. Fingers crossed for you everything gets sorted once she gets some considerate treatment mate; take it easy.
  27. paddy
    5,196
    145
    There is always a temptation to be polite and not rock the boat with these things but TBH you just have to fight to get the best service, Your Gran cant so she needs you to fight her corner mate, deal with the doctors and management and bypass the "care ? " assistants etc.
    Good Luck..
  28. paddy
    5,196
    145
    My turn :) reversing lights have packed up !
  29. warren_S5
    7,210
    2,486
    Nooooooooooo....
    All VCDS issues resolved, but my driver window glass is rattling and there is bad wind noise coming from round the frame. Same with previous one so some things never change!
