one touch windows problem
Ash187 Apr 16, 2010
  1. Ash187
    7,495
    743
    Hey guys,
    I have a 2005 A3 Sportback
    I have noticed that my windows are playing up... but its intermittent. the drivers door was not doing the 'one touch down'. i have searched the forum and found that i can reset the windows by opening the windows by holding down the switch and then closing them again by holding it down all the way. I have done the reset procedure and the drivers window now sometimes works on the one touch and sometimes doesnt.
    Now i have noticed that the rear passenger side window is doing the same but only when i am doing it from the drivers switch. If i open the window from the rear passenger door the one touch works...
    now im thinking is it a problem with the actual switch in the drivers door or is there something else i can do to make it work properly?
    thanks in advance guys
  2. Spin140
    Spin140 Well-Known Member
    2,196
    186
    I'm no expert but you seem to have identified the issue yourself as a faulty switch on the drivers section.
  3. tdisportuk
    tdisportuk Member
    460
    could be a faulty switch, but like you said to programme it just hold them for a few seconds whilst going up and down then one touch is meant to work.
  4. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    I had this problem with the window shutting on one touch, but getting to the top and then opening again by a few inches. I spoke to my local Indy and they said that the sensors are very sensitive, and if your trying to shut the window on one touch and go over a bump at the time, it can activate the anti-close sensor which thinks that something is shut in between the window and the frame. It could be that this sensor is on its way out??
  5. defer
    defer Member
    87
    My 08 S3 was doing this, i mentioned it to Audi and they did a software upgrade on it, never done it since.:icon_thumright:
