One touch elec window
arthurfuxake Sep 4, 2006
  1. arthurfuxake
    1,308
    Hi,
    My drivers side elec window button isn't working as it should. It doesn't go down by itself when I press it down all the way (ie through both clicks). I need to give it a seriously hard press, and then it does go all the way down on its own. It works perfectly for the closing, so I'm guessing that it's just some dirt in the switch. Does anybody have any suggestions to fix it. I don't want to strip the door card off, do you think a squirt of wd40 will work, or will it wreck the soft rubber covering on the switch?:uhm:
  2. maz1975
    maz1975 New Member
    23
    You could try blasting it with those air cans that you use to clean keyboards...I'm sure you'll be able to pick one up from PC World or something
  3. Olly_K
    Olly_K Administrator
    2,678
    yeah a can of compressed air with the "straw" attachment should do the trick !
