One cylinder stopped firing
sekenzo Mar 30, 2012
  1. sekenzo
    sekenzo Member
    102
    Changed spark plug - no change
    Swapped coil pack - no change
    No oil in plug well so can rule out arching
    Any other suggestions?
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Check the coil pack loom as these deteriate due to the heat in the area, the insulation cracks and breaks down ;)
    I had to replace mine awesome gti do a replacement loom to splice in if this is the case with yours, think it's £30 iirc
  3. BENJAMIN
    BENJAMIN Active Member
    503
    93
    If its an AGU engine it will more than likely be your ignition amplifier on the side of the air box. A very common failure.
  4. aragorn
    18,600
    870
    Yeh, quite often cylinder 2 as well for some odd reason!
  5. xCoupexAshx
    xCoupexAshx All Torque
    i have the same problem and have tried changing the ignition amplifier too. to no success. when you say cylinder 2 do you mean 2nd from the right as in |4|3|2|1| layout? ta
  6. aragorn
    18,600
    870
    Cyl 1 is at the Drivers side of the engine.
    I guess its possible the A3 is wired differently, but on the A4 its almost always cyl 2 that drops out first when the ICM dies.
  7. sekenzo
    sekenzo Member
    102
    It's cylinder 2 that died on mine as well! How much will the ignition amp cost? Thanks!
  8. A3 Oly
    A3 Oly Member
    247
    about 70 - 100 for new bosch job or 20-40 second hand, although u dont know wether used ones are alreet or not
  9. sekenzo
    sekenzo Member
    102
    Thanks. Have anyone tried the 2.0t coil pack conversion on an AGU? Any idea / guide on what is involved?
