OMG this might old news but it's COOL
S3 TAM Sep 22, 2010
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    I've just come across this. you may already know this but i just found it out.
    Climate control information display.
    If you press and hold the recirculation button then press the up arrow on the right let go of both you should see 1C appear on the screen. If you then press the recirculation it will give you the info for that block "let's say". There are 89 "blocks 1C - 89C" so far I have figured out that block 17C is speed "KM/H", 27C is engine speed and I think 49C oil Temp.
    I'm might be really sad but I think this is cool now we have digital display of speed "kmh", RPM, Oil Temps no need to get oil temp gauge now.
    There are lots of other "blocks" with info but not sure what i'm looking at.
    Does anyone know of this and what they all are?
    Here are some pics
    Block 49C "oil temp". It did fluctuate between 91 and 99 degrees while driving.
    Engine RPM on idle
    Engine RPM tapped on the throttle
    And Engine speed
    Love it.....:rock:
    Edit: Just finished putting a few more pipes on. Yey
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,118
    1,959
    I thought the same until you think you have to look down at it rather than on the dash,so it becomes a bit dangerous....just what I thought when I found out.
  3. Danny Cawsey
    Danny Cawsey Cawsey
    516
    i will be giving this a go in the morning.
  4. superkarl
    superkarl MAN OF STEEL
    9,329
    2,334
    thats cool.
    where do you get all/most of your pipes from?
  5. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    Early Ford's had a similar thing on the speedo's , It had so many diff details. Used it a few times. I'l give this a try. Cheers
  6. talentwalsh
    talentwalsh Member
    139
    Block 51 gives coolant temp and block 20 gives battery voltage, there is a few other handy ones floating around.
    Get them all here AudiWorld Tech Articles
  7. S3 TAM
    624
    10
    I got 3 meters of 4mm, 6mm, 8mm and 12mm from mr silicone "i think" on ebay and loads of JCS HI GRIP CLIPS.
  8. S3 TAM
    624
    10
    I came across this last night. I dont think this is for are cars it say 1998 on it and it only goes upto 61C. Plus it say 28C is rpm but on mine 27C is rpm. Maybe they put a few more features on our models
  9. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    does one of thsoe do g/s? :p
  10. S3 TAM
    624
    10
    I'm not sure to be honest matey still trying to figure them out.
  11. Lee172
    Lee172 GT3071
    430
    I heard about this but never knew how to do it! Does anyone know a list which is 1 - 89?
  12. talentwalsh
    talentwalsh Member
    139
    More than likely, a lot of the blocks dont seem to match up but they are not far off, handy tool though!!
  13. devan
    devan Member
    119
  14. vetch
    vetch S3
    430
    Block 49 is actual coolant temp. Block 51 is displayed coolant temp.
  15. vetch
    vetch S3
    430
