OMG HELP WANTED
trinistyle Dec 9, 2011
  1. trinistyle
    trinistyle New Member
    Drove my car today and noticed the abs light is on so decided to take a detour to my mates garage and get it checked.
    Fault code osf abs sensor short circuit to positive & data bus message missing from engine ecu.!!!!
    Anyone got a clue on whats those codes MEANS :sos:
  2. quattrojames
    14,050
    576
    What car have you got? Sounds like the ABS sensor is goosed.
  3. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    Speed sensor on that wheel is goosed. Easy job to fit a new one.
  4. trinistyle
    Already replaced the osf abs sensor and checked continuity from the abs module to the sensor all the wiring seems ok but the weird thing is I get the same code when the sensor is unplugged or connected...(Short circulit to postive & Data bus missing message from engine control module) Its driving me Nuts :asskicking:
    By the way Its an Audi A4 Quattro 2000 model B5
  5. Broken Byzan
    13,237
    465
    ABS ECU needs to be reworked. The fine wires break up causing all sorts of issues. The first of which is sporadic failure and eventual non communication.
    BBA reman do them IIRC
