Old style RS4 replica wheels with 235/40/18 tires
sekenzo Aug 21, 2012
  1. sekenzo
    sekenzo Member
    102
    Will they fit my A3?
  2. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Are they 5 x 100?
    What's the offset?
    And those tyres are slightly too big, you could use them, but your speedo wouldn't be very accurate. You need 225/40
  3. colicabcadam
    colicabcadam Guest
    why would the speedo be out if a tyre was wider ? confused lol
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Because the rolling circumference has increased by 25.2mm pushing the speedo out by -1.24%...not much out, but still out.
  5. colicabcadam
    colicabcadam Guest
    if the tyre is wider ? i thought the wheel size and profile of the tyre determened the circumferance ?
    so a 355/40/18 has a larger cirumference than a 205/40/18 ???
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
  7. aragorn
    18,608
    871
    the profile number is a % of the width.
    So a 225 / 40 means the height of the tyre is 40% of 225.
    A 335 / 40 is 40% of 335.
    Therefore, you make it wider, it gets taller too.
    If you look at the tyres fitted to the RS4 for instance, they used 255/35r18's, which are pretty much identical in circumference to the 225/40r18's everyone uses on the S4.
  8. superkarl
    9,610
    2,481
    The profile, in this case 40, is a percentage of the width. Its not a size, not 40mm.
  9. jojo
    28,998
    3,652
    YES. :yes:
  10. sekenzo
    sekenzo Member
    102
    They are pcd 100 and 112. Will they cause issues will rubbing on the wheel arch?
  11. colicabcadam
    colicabcadam Guest
    oh - nice to know this !!!!
  12. superkarl
    9,610
    2,481
    depends on width and offset.
    But at a guess they will be the same as mine, 18 x 8, offset of 45, meaning you will need spacers to clear thew struts, but no arch rubbing no. For the record I run 15 and 20mm spacers.
  13. jojo
    28,998
    3,652
    replicas are generally the correct offset @ET35, but later ones are ET45. With 235 tyres, I would say they will scrub on your arches on an A3, an S3 would be ok, as they have a bit more room to play with being wider etc.
  14. Jpd89
    Jpd89 Member
    118
    Can I jump in here as well? Trying to see if 9jx18 wheels with 35 offset would fit? Would need 20mm adapters as well so would the offset go to 15 or 55?!
  15. superkarl
    9,610
    2,481
    offset would go to 15 with 20mm spacers.
    use this:
    Wheel Offset Calculator
    measure your current clearance and then put the wheel specs in
