ok i give in, need help where to run pipe for boost gauge
epox Jun 14, 2014
  1. epox
    epox Active Member
    773
    74
    as title stripped down dash, removed fuse and relay board and cant find any where to run pipe int engine bay.
    anyone got links or pics.
    thanks
    Mark
  2. <tuffty/>
    21,686
    4,115
    You won't find it that way dude... you need to remove the wiper blades and the scuttle panel then you can see the plastic cover that sits under the wiper mech... this is where the wiring loom transitions from inside to outside the car... you can drill a hole in this (I undid it to ensure that there was nothing behind where I was drilling... fitted a grommet and fed the hose through there...
    Pics can be found here as you need to access this for cruise control fitting too
    http://www.audi-sport.net/vb/a3-s3-...how-fit-cruise-control-a3-1-8t-pic-heavy.html
  3. limbo118118
    limbo118118 LORD
    501
    53
    as above, take scuttle off and remove wipers... theres a white box take lid off... theres holes with wires going through i just used a coat hanger to souce it through to by the fuse box area. (fuse box needs loosening to get behind) my vac hose goes off a t piece off the dumpvalve also.
  4. <tuffty/>
    21,686
    4,115
    Its black on later cars... think it was white on prefacelift stuff...
    Lee.S and limbo118118 like this.
  5. epox
    epox Active Member
    773
    74
    Thanks guys.
    Went the hard rout and went through the gromit next to the pollen filter, changed the filter while I was there:) .
    Wipers are solid and could only get the one off.
    Will post some pics when done.
    Could not see any boxes at the driver side cables just came through the bulkhead, could be a box further along though.
    Cheers mark
  6. epox
    epox Active Member
    773
    74
    Wee up date, defo no box on face lift car, in the location as in tufftys link for cruse.
  7. <tuffty/>
    21,686
    4,115
    its a cover not a box... in the picture below its the white cover (early S3's), on face lifts it will be black... its held on by 2 x 10mm plastic nuts IIRC
    This is the cover you need to remove/drill into
    Alternatives are... the grommet next to the pollen filter... the pollen filter casing is easily removed (again, 2 x 10mm plastic nuts) and affords better access when removed...
    There is also a hole behind the pollen filter housing too
  8. S3Hendry
    S3Hendry Member
    189
    I have a silly question lol
    As far as I'm aware you connect your gauge to the tubing that comes from the DV?
    Do you put a t piece in the tubing or do you connect the tubing directly to the gauge ?
  9. Freeman_1986
    Freeman_1986 Member
    169
    21
    Tee into the tube coming out of the top of the DV mate
  10. S3Hendry
    S3Hendry Member
    189
    Allow me to hijack this thread..
    Bought a gauge kit off ebay.. A digital one with a boost sensor, so I just have to run a cable into the cab.. Anyway what the hell is this thing that came with kit? Do I need? Looks a filter or summit
  11. <tuffty/>
    21,686
    4,115
    Its a filter for the vacuum pipe you need to use for the boost sensor...
  12. BENJAMIN
    BENJAMIN Active Member
    503
    93
    Beware of the moisture filters splitting.
  13. S3Hendry
    S3Hendry Member
    189
    Ah ok moving on to more difficult things, where can I connect the gauge power cable to?
    Can I connect it up to the dimmer block? Do I just solder the cable into one of these? Advice please
  14. S3Hendry
    S3Hendry Member
    189
    Decided to abandon the operation until tomorrow, couldn't get the wipers off to gain better access, will go buy a puller tool tomorrow and teach these stubborn **** wipers a lesson!
  15. epox
    epox Active Member
    773
    74
    Go in at the pollen filter, no need to take the wipers off, remove the glove box and feed tube int the car and run wires behind the radio to the light switch
    mark
  16. S3Hendry
    S3Hendry Member
    189
    That might be the way ahead mark, save buying a silly tool.. Have you got your gauge wired up?
  17. epox
    epox Active Member
    773
    74
    Ye got it wired up to the dimmer so it only comes on when the lights are on, its a red led type. Not really bothered about having it on all the time, in saying that I'm waiting on a replacement as its not reading correctly. Its on the blue/grey wire.
    Mark
  18. S3Hendry
    S3Hendry Member
    189
    Hold on I have digital one, mine is a numerical display, so I will need power when the lights are off, hmm what do you think?
  19. epox
    epox Active Member
    773
    74
    You will have to use a live when ignition on then, there will be one at the light switch, not sure which one. There might be one at the dimmer but I did only want it on with the lights on.
  20. epox
    epox Active Member
    773
    74
  21. S3Hendry
    S3Hendry Member
    189
    Awesome mate appreciate that
  22. S3Hendry
    S3Hendry Member
    189
    Got the bloody thing fitted, arsehole of a job! After the head scratching and swearing I discovered something is not right.. As you can see in the pic it doesn't read correctly, that's meant to be -2. Wiring issue or faulty unit?
  23. epox
    epox Active Member
    773
    74
    Ye the on I got was faulty as well, looks like the same type. Was it in a red box performance instrumentation.?
    Mark
  24. S3Hendry
    S3Hendry Member
    189
    Aye red box, purchased of 'Yoopar' through ebay, did you happen to buy it off the same dude? Asked for a replacement but yoopar response didn't best please me tbh he thinks it's a wiring issue! If they supply a replacement I'm going to ask for a clock type gauge, not to keen on the digital display.
    Turbo is boosting 11psi max, think stock is 12 psi, so quite happy considering my car is stock apart from badger TIP and cone.
