ok...... am on the hunt now - S4 Front Brake calipers
AndyC Dec 12, 2010
  1. AndyC
    AndyC Moderator Staff Member Moderator
    719
    I know this has been asked before....... and answered but I couldnt find it.....
    which exect brake setup fits the B5 S4......
    was it the b6 or b7 front setup (the single pot type) that goes straight on.....
    and do you need the b7 321mm discs? (already got these just in case)
    the EVO calipers were just not a close enough fit to be safe...... so pulled that project.
    help appreciated guys.
    Andy
  2. aragorn
    18,491
    855
    Lots of brake setups fit...
    Any B6 and B7 braking setup will fit a B5 S4.
    If you want to use the 321mm B5 S4 disks, you can use the B7/Allroad single piston calipers, but this doesnt give you anything, other than a slightly better caliper and perhaps a better selection of pads, as the disks are the same as the standard S4 ones.
    Alternatively the 345mm B6/B7 S4 disk and caliper will work, and provides a decent upgrade.
  3. AndyC
    719
    ah! I have the larger discs.
    its really an economic upgrade with better pad choice I am after....:)
  4. aragorn
    18,491
    855
    Ok, well the standard B5 S4 uses 321mm disks, which are also used along with a single piston ATE caliper on B6 and B7 A4 models (2.0T and other hot versions) and also on bigger engined Allroads
    B6/7 S4 has 345mm disks, with the same caliper (S4 carrier just spaces it over a bit)
  5. AndyC
    719
    ah, its the B7 disks I have then.
    right.... now just gotta find some
    thanks as ever for the excellent help
    Andy
  6. AndyC
    719
    AUDI - A4 (8E2, B6) - S4 quattro
    03.03-12.04 -
    253 344
    4163
    AUDI - A4 Convertible (8H7, 8HE) - S4 quattro
    03.04- -11.08
    253 344
    4163
    AUDI - A4 (8EC) - S4 quattro
    11.04- -11.08
    253 344
    4163
    AUDI - A4 Avant (8ED) - S4 quattro
    11.04- -11.08
    253 344
    4163
    AUDI - A6 (4F2) - 2.0 TFSI
    06.05- -
    125 170
    1984
    AUDI - A6 (4F2) - 2.4
    05.04-10.08 -
    130 177
    2393
    AUDI - A6 (4F2) - 2.4 quattro
    01.05-10.08 -
    130 177
    2393
    AUDI - A6 (4F2) - 2.8 FSI
    10.08- -
    140 190
    2773
    AUDI - A6 (4F2) - 2.8 FSI quattro
    10.08- -
    140 190
    2773
    11.06-10.08 -
    154 210
    2773
    06.07-10.08 -
    154 210
    2773
    10.08- -
    162 220
    2773
  7. AndyC
    719
    seems this is what the B6 S4 calliper fits
  8. aragorn
    18,491
    855
    yep, the A6's listed wont have a 345mm disk though i wouldnt think, they'll use the same caliper but a shorter carrier and a 320mm disk i recon.
  9. Nez
    Nez Member
    598
    Also you can go for the RS4 B5 Brakes :)
  10. AndyC
    719
    Nez, how do you get on with the downpipes?
    there are some RS4 brakes for sale, but you need uber expensive discs!?
  11. aragorn
    18,491
    855
    ye the disks are about 300quid each unfortunately, which is why you often see the calipers being sold off for peanuts.
  12. a4turbos
    a4turbos New Member
    21
    I have a front set of S4 B5 facelift calipers for sale. These are off a yr 2000 car and use the 321mm disks. I also have the used set of disks which could be used as a last resort, theres not much life left in them.
    let me know if they are any use to you. cheers Steve
  13. aragorn
    18,491
    855
    I'm imagining he already has those on the car!
  14. AndyC
    719
    thanks for the offer, but yep i have those.... :)
