Oilfilter tool?
rasA4 Oct 7, 2011
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
  2. Bradderz_1988
    3,923
    231
    I use water pump pliers or my hands but on my car I use a spanner as I've one of those k&n wrentch off's fitted.
  3. aragorn
    17,960
    702
    The bigger B6 filter has a "thing" on the bottom you can slot a screwdriver shaft into.
  4. Oranoco
    Oranoco Well-Known Member
    3,799
    349
  5. Bradderz_1988
    3,923
    231
    ^^^ yes there a good tool aswel don't have one personally but have used them in the past and they are better than chain straps.
  6. adamss24
    adamss24 Well-Known Member
    4,557
    394
    I use a Laser oil filter tool from local halfords, the best i've worked with and it's handy when replaceing pullys as well.
  7. rasA4
    3,287
    119
  8. OldRedEyes
    OldRedEyes Member
    445
  9. Broken Byzan
    13,237
    465
  10. Bradderz_1988
    3,923
    231
  11. adamss24
    4,557
    394
  12. aragorn
    17,960
    702
    No-one just beats and old screwdriver thru the filter then?
  13. Oranoco
    3,799
    349
    Used to do that on old Metros and Novas
  14. THE MONSTER
    THE MONSTER Member
    224
    This is the one I used it got the most votes in a survey when I looked for one at the time..
    It's all about getting in to turn the Filter with your hand..
    I always undo the water top up reservoir and move it to one side so you can access the oil filter better..
    I only used this because some Mechanic over tightened it..
    When you Screw in your new Filter use a pair of Gloves to tighten the Filter Hand tight then you will never need a Wrench again you should be able to unscrew again with gloves on..
    No need for a Wrench should only be done up hand tight anyhow..
    DRAPER 10784 OIL FILTER WRENCH 100MM CAPACITY | eBay
  15. Oranoco
    3,799
    349
    My oil filter tool is here, we call him Chris and he's currently making the coffee round. lol
  16. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I always use the bluefin one posted earlier. Far easier to use than any other chain type I had used in the past.
