  1. Masterm8fo
    Masterm8fo Warmonger
    342
    what oil u fellas using ???
    just topped up with some Castrol SLX 2 synthetic (0/w30?)as my engine was bone dry
    not a fecking drop in it
    thinking it will need more than the 1 litre i whacked in last nite
    this is pretty expensive oil the synthetic stuff (app.esp for VAG engines with AVS service intervals)
    40 quid for 3.5 litres
    this what u all using ????
  2. nervus
    nervus Well-Known Member
    1,370
    121
    Mobil 1,
    It is expensive but not as much as an engine rebuild!
  3. imported_gek
    imported_gek Guest
    Castrol SLX £49 for 4 litres from Halfords /ubbthreads/images/graemlins/frown.gif
  4. dickys3
    2,963
    23
    I use Mobil 1 also.
    Its cheaper than Castol SLX at my local halfords and its VW503.01 approved for my AVS Servicing!
    I didn't think it was that expensive?
    Rich.
  5. jcs356
    jcs356 Brum brum
    2,734
    70
    I'm using fully synthetic VAG Synta Gold - about £23 for 5 litres from GSF. It gets changed every 5000 miles as I'm not following the variable service routine as I don't agree with it.
    I've been advised that you only need the tip-top Castrol stuff if you are following variable servicing. If not, any quality synthetic will do.
