Oil usage
a4-er Feb 8, 2012
  1. a4-er
    a4-er New Member
    21
    My a4 2001 mod 1.6 use about 1 liter oil on about 600-800 km. no oil leak.. No black or blue smoke. The car has just gone 107 000 km.. Changed oil and filter. Didn help. Had it twice to a workshop. They couldent find anything.. I think 1 liter on 600 km sounds like alot.. Anyone might know what it is?
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    Sounds like a lotfrom a rough conversion to miles.How long have you had it and has it always done this?
  3. a4-er
    a4-er New Member
    21
    I bought the car in september. It has been like this since. Told the dealer. But he said it was nothing. Some cars just was like that..
  4. TSport150plus
    TSport150plus New Member
    The oil filter would hold that much, after running the engine did you top up?
  5. Bradderz_1988
    3,921
    231
    Oil cooler possibly ?? How's your coolant looking ??
  6. a4-er
    a4-er New Member
    21
    No oil in the cooler.
  7. a4-er
    a4-er New Member
    21
    Changed the oil and filter. But still.. Every 600 -800 km, the oil lamp turns on. Gotta put on 1 liter of oil every second week. Expenssive oil too..
  8. Mike B
    1,101
    40
    Is the coolant clean?IF so and there are no leaks its got to be burning it.Try a compression test to see if you have got wear in a cylinder or two.I would say that its using at least 3 times more oil than normal
  9. a4-er
    a4-er New Member
    21
    Well. from the values of the exhaust emission, it was looking good. Dunno if that helps.
  10. Mike B
    1,101
    40
    If the oil is going down at this rate it got to show up somewhere.Do you get any blue smoke if you let it idle when hot and then rev it hard?
  11. a4-er
    a4-er New Member
    21
    No. Normal grey smoke when hot. A little more grey smoke when cold. Tried putting a finger in the exhaustpipe to feel if there was oil. But i think it was just condens.
  12. Mike B
    1,101
    40
    Grey would be condensation in this weather but not too much if its hot.I would still try a compression test if I were you.Why is it kms not miles?sounds too low for this age.Can the mileage be right?If its done a lot of short journeys with the choke that would increase wear
  13. a4-er
    a4-er New Member
    21
    Guess i have to take that test. Its just so damn exspensive here. Miles in USA are different than miles in europe. Dunno why the low mileage. But the cardealer told me there was an old schoolteacher couple that owned the car. So i figured it was nicely used.
  14. aragorn
    17,956
    701
    lol miles are miles, there are no regional variations.
  15. a4-er
    a4-er New Member
    21
    So then 10 km = 1 mile in america too?
  16. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    A kilometer is = 0.621371192 miles in ANY country.
    I deal with KMS every day due to my job and having done international driving I can honestly say i have never heard of 10kms equating to 1 mile.
  17. a4-er
    a4-er New Member
    21
    10 km is the same as 1 mile in scandinavia
  18. S4_dan
    2,699
    157
  19. a4-er
    a4-er New Member
    21
    A mil is a unit of distance, most often used to measure geographic distance, very common in Norway and Sweden. Today, it measures by definition 10 kilometres, (≈6.2 (statute) miles) but
    earlier in history it had different values. [1][2]
    The word is derived from the same source as English mile, a measurement which historically has had many different definitions throughout Europe. In Sweden and Norway, a (statute) mile is often called "engelsk mil", lit. English mil(e).
  20. Mike B
    1,101
    40
    But if its genuine low miles I bet the teachers didnt do many long journeys so its probably had more wear than normal especially in a cold climate with lots of choke use.Where are you inside the arctic circle??
  21. a4-er
    a4-er New Member
    21
    Pretty close to it. Inside :p
