oil temperature sensor location??
Andyb5 Apr 30, 2013
  1. Andyb5
    Andyb5 Member
    68
    Hey all
    My oil temperature has stopped working on the dash and the orange sensor warning light is on in the middle of the dash too. Im looking to get one and replace it myself but was wondering if anyone could point me as to where this is located in the engine bay?? and is it easy to get to/change?? its on an x reg b5 1.8t
    cheers
    Andy
  2. Sulli79
    Sulli79 Active Member
    541
    37
    Pretty sure it's on the top of the oil filter housing below the intake manifold, best access to there is undoing the screws that hold the coolant tank and moving the tank out of the way
  3. aragorn
    18,369
    828
    If you have a digital clock, its part of the sensor in the bottom of the sump.
  4. Sulli79
    541
    37
    Forgot about that, yeah on an x plate, should be in the sump, remove under tray and you should see it
  5. Andyb5
    Andyb5 Member
    68
    Ill give it a go this weekend
    cheers for the replies
