Oil temp gauges
waring192 Jan 18, 2010
  1. waring192
    waring192 Member
    349
    You know the oil temp gauge in the cluster, well the oil temp bit you can access through the computer give very different readings on startup.
    The gauge sometimes shows 90 while the comp one shows around 50.
    My question...which one is more "up to date"?
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    The gauge in the cluster shows the coolant's temperature.
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,458
    597
    As above
