  1. Funkyfin2000
    Funkyfin2000 Member
    489
    Hi there,
    Getting this error on an A3 Quatty. Believe there is a sensor in the sump? Whereabouts is the sensor?
    Any idea on price at all for this?
    The faults on Vag.com are:
    Address 17 -------------------------------------------------------
    Controller: 8L0 920 980 C
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 05444
    Shop #: WSC 00000
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1352033
    2 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    30-00 - Open or Short to B+
    29-10 - Short to Ground - Intermittent
    Any help appreciated
    Rich
  2. The oil level sensor is on the bottom of the sump. The electrical connector faces towards the rear of the car.
    If it's like mine, you may have knocked off, or damaged the connector. The sensor itself is usually ok.
  3. Funkyfin2000
    Funkyfin2000 Member
    489
    thats great mate...
    how do you fix a broken electrical connector :S
    or is it just a case of reconnecting it?
    Rich
  4. If you're lucky it will just need reconnecting. But you will prbably need a new connector body at the least. Get one from your dealer.
    My latest one has been reduced to a few bare wires, so I've had to get a new loom as well.
  5. Funkyfin2000
    Funkyfin2000 Member
    489
    cheers mate, will get it checked out probably saturday!
    Is the sensor at the back of the sump, back further than the sump plug presumably...
  6. The sensor is to the side of the sump plug.
  7. Funkyfin2000
    Funkyfin2000 Member
    489
    Cheers dude!
