Oil Sensor Warning Light
Gavin G Feb 24, 2011
  1. Gavin G
    Gavin G Active Member Audi A4 S-line owners group TDi saloon
    184
    31
    Why would this be coming on? Ive checked oil levels and the seem fine? Any ideas? Im going to do an oil change this weekend so would this maybe put the light off? Thanks for your help:yes:
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Could be a dodgy sensor or might be an issue with your oil pressure! Try doing an oil change and see if that makes any difference. If you have a pressure issue you really dont want to be driving the car too much.
  3. m.dub
    m.dub New Member
    Mines the same that annoying beep and the oil sensor warring light, im sure this just relates to a faulty sensor. iv just had a service and its still beeping away but at over £70 for a new one ill live with if for a while.
  4. Broken Byzan
    13,237
    465
    If the light is red, stop driving and get the pick up in the sump changed before it costs you an engine
  5. finesse
    finesse Active Member
    2,805
    as above, small money incomparable with a new engine
  6. DenCar
    DenCar Member
    404
    Yep, change the sensor, if light is still coming on then have it looked at as it may be a blocked oil pick-up or faulty pump.
    DC
  7. Westy
    17,443
    1,105
    Get the car scanned, it will be rare for the sensor to be duff but a VCDS scan will tell you. It will be easier and cheaper to get the oil pickup checked and cleaned/replaced rather than spend £80 on a sensor that might not be the problem.
  8. DenCar
    DenCar Member
    404
    Out of interest, how much approx for a new pick-up and oil pump + labour.
    DC.
  9. Westy
    17,443
    1,105
    You shouldn't need a new pump or pickup pipe, just a clean and a new strainer which costs a few quid. A new pump and pickup pipe wont be particularly cheap.
    My mechanic charged me £80 to remove the sump, pressure test the oil pump, clean the oil pickup pipe, and replace the strainer (filter). But he was already doing a service so the sump was drained of oil anyway.
  10. TOM.S
    TOM.S Active Member Silver Supporter
    564
    i had the same problem 3 weeks ago. its the oil pressure/ faulty sensor.
    deffo worths changing it, before you do some serious damage to the engine.
  11. physk
    physk Member
    34
    I've got the same problem
    red light with 3 beeps
    Oil levels are fine, i think i put a little too much in since i didnt really have the car on level ground and it messed up
    this was after i busted my sump and fitted a new one in
    Vagcom didnt throw up any errors regarding it
    i was told by a friend, its probably a faulty oil pressure switch. Been driving the car for the last 2 months been absolutely fine in every way
    Its due a service nowish,
    so will be changing oil again and new oil filter etc
    hopefully itl go away. anyone know what else it could be
    Dont europarts have the oil pressure switch for under a tenner
  12. Gavin G
    184
    31
    My light isn't red though its orange and has an oil can with sensor written beside it. Your problem may be bigger than mine by the sounds of it if it's red? :sadlike:
  13. danger S3
    danger S3 Member
    374
    19
  14. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    How can you drive around with that thing flashing.....it would be mind wars with me......it bugs me when the washer fluid is low.....
    just think of a worse case scenario ...if it is on because of a dodgy switch, what can it do extra if things become worse and the pressure actually drops....it would not do any extra warnings....... that is your final warning!!!
  15. Westy
    17,443
    1,105
    I agree with Dave, that is one warning i wouldn't be driving around with!
    Dan5115 likes this.
  16. physk
    physk Member
    34
    It's been 4months and about 3k miles lol
    Will have it checked out by a mech
    Mind you
    It doesn't do his at high speed or motorway
    But as soon as I drop from high to low speed
    The light beeps
  17. DenCar
    DenCar Member
    404
    I would think that at high speed your pump is working harder and pumping the oil at a higher pressure, at lower speed the pump is working less hence less pressure, i may be wrong about this, but i would be a little concerned if i were you.
    DC
  18. Sandip
    2,456
    99
    It's either your pick up or your oil pump. Either way if you have the sump off to do the pick up, you may aswell do the pump at the same time
    What service are you on, longlife (5w30) or regular (5w40,10w40)?
  19. jojo
    28,945
    3,600
    Becareful with over filling these 1.8T's, a friend of mine mistakenly thought the low oil pressure warning as being low engine oil and overfilled his 1.8T on his Passat, it was halfway up the dipstick! He's an old chap mind, and he never thought of checking his dipstick first before filling! Anyways, the results of this is the oil came up the breather and filled the intercooler with oil, and it also pushed a load of **** into his sump, which blocked the oil pickup, so no oil pressure and a seized engine!!
  20. physk
    physk Member
    34
    I'm going to change my oil when I service my car in the next few days
    Putting 5w40 in
    Whilst I had these probs I just put in castrol 10w40
    Just to double-check there wasn't any leaks elsewhere
    I've verified that
    So now its just do te service and hope the noise goes away
    Really annoying an worrying sometimes
  21. DavidW
    DavidW Member
    211
    Is the 10w40 not semi synth though?
  22. physk
    physk Member
    34
    It is indeed
    It was always meantto be temporary
    It was put after the sump job to ensure that everythig was fine
    Just haven't had time since then to change it since I'm moving between Manchester and Sunderland
  23. aragorn
    18,545
    865
    If its yellow and says "SENSOR" at the bottom its a fault with the oil LEVEL sensor, which sits in the sump and registers how much oil is in the sump.
    If its this, then its possibly just a wiring fault, or a sensor fault, and isnt a big issue so long as there is actually oil in there.
    If its RED and says nothing at the bottom, its PRESSURE related, and continuing to drive the car will most likely result in a wrecked engine.
  24. Gavin G
    184
    31
    Im in the yellow situation thank you :)
  25. Gavin G
    184
    31
    Did my oil change today found the problem, the oil sensor had become unplugged, problem solved thanks folks :D
  26. Westy
    17,443
    1,105
    Nice one. At least it's not a blocked pickup.
  27. physk
    physk Member
    34
    hopefully my problem sorts out just as easily :)
  28. Cameron Brunt
    Cameron Brunt '02 A4 Quattro 3.0
    Boys,
    Had this happen to me tonight. Yellow with sensor underneath. Happened after a hard drive (in the rain) once I slowed down in the city. Question; If my oil level is good, can I drive 25 minutes to a mechanic without worry?
  29. timberman
    timberman New Member
    20
    No you cant drive it, if your pressure is low you risk serious damage as your bearings will burn out. I've learned the hard way.
  30. JohnDuh
    JohnDuh Member
    151
    19
    Reviving an old thread here for peace of mind.
    This morning my car beeped at me with the yellow oil sensor symbol. This was before I even cranked the engine, so i'm thinking faulty sensor.
    When i read this here, this would mean I'll have to change the sensor or check the wiring, but would still be safe driving the car (while keeping a keen eye on the dipstick of course)
  31. JohnDuh
    JohnDuh Member
    151
    19
    Just for the interest of anyone reading this. My car has been loosing oil, so the yellow is definitely the oil level, just top up whenever the light goes on and you'll be fine.
    Since then the car developed the red light problem, so I'm now looking for a solution to that one :-(
