oil pump replacement
hubbo1 Jun 13, 2012
  1. hubbo1
    hubbo1 Member
    117
    hi, is there any info on here about how to replace the chain driven pump with the geard pump?
    thanks
  2. madstaff
    madstaff Member
    105
  3. VagPro
    VagPro Active Member
    442
    34
    Are you having trouble with the Oil Pump ? I know Sanburn can do away with the whole silly balance shaft assembly and replace it with the reliable oil pump setup out of the 1.9 TDI engines. Give then a call 02476637376 and speak to Wayne
  4. hubbo1
    hubbo1 Member
    117
    hi
    have got gear driven unit just need some tech advice on removal
    thanks
  5. hubbo1
    hubbo1 Member
    117
    thanks
  6. VagPro
    442
    34
  7. hubbo1
    hubbo1 Member
    117
    hi
    2005-a4-s-line 2.0 tdi-blb engine-cvt multitronic.
    thanks very much-also is there any info for cam belt change? as i imagine this will need to be changed?
    many thanks
    andy
  8. madstaff
    madstaff Member
    105
    Sorry to barge in on this, but would you have the relevant information on Elsa on how to replace the injectors on a 2007 A4 TDI, fitted with a 16V PD TDI, engine code BRD.
    A step by step guide would be a help, and the relevant torque settings would be fantastic.
    Thanks.
  9. VagPro
    442
    34
    Hi Andy,
    Apologies for the delay mate, attached procedures below for:
    Removing and Installing Oil Pump Chain Driven
    Removing and Installing Oil Pump Gear Driven
    Cambelt Replacement
    https://dl.dropbox.com/u/38150502/AudiSport/BLB%20Oil%20Pump%20Replacement.zip
    Hope this helps
  10. VagPro
    442
    34
  11. Lee Applin
    Lee Applin Guest
    have you not csalled the main dealers to check to see if its due a recall on them? my car was done a few months back all for free
  12. madstaff
    madstaff Member
    105
    Thanks for that. :thumbsup:
    Already had all 4 done in its life - had 1 done, then another 1 done then 2 through recall i believe, all before i owned it. Just waiting for Audi to inform me if its had all 4 done, when and where.
    Been suffering starting problems when my car has not been used for a couple of days which i thought could possibly be fuel pressure related, hence the (hopefully not) need for the guide to replace the injector seals.
  13. hubbo1
    hubbo1 Member
    117
    thats great krumz
    many thanks
  14. Lee Applin
    Lee Applin Guest
    to me that points more towards air being drawn in somewere, ie leaky fuel filter / fuel pipe fitting on the low pressure side
  15. madstaff
    madstaff Member
    105
    Changed the fuel filter the other day, fitted a genuine VAG filter and put the supplied new 'o' rings on the thermostatic t piece - which did feel as though it was definately a good fit when pushed in.
    Fingers crossed.
  16. Bald man
    Bald man Member
    59
    I am going to have the gear driven oil pump replaced to 1.9 version any else had it done any issues ?
  17. VagPro
    442
    34
    I believe you need to change the sprocket, chain, chain guide and pump. Also think you need to plug the oil supply holes in the block to the balance shaft assembly.
