Oil pump change.
g60leigh Oct 4, 2013
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    When changing the oil pump (just from maintenance point of view. No sign of failure) do you change the chain and tensioner too?
  2. <tuffty/>
    21,957
    4,229
    You don't need to no but... if you plan to then you have to remove the crank pulley and the front cover to do it... you will need a new crank seal and crank pulley bolt too... torque is 65ftlbs + 90 degrees for the crank bolt
  3. g60leigh
    1,674
    207
    Not planning on changing chain unless need to. Was considering changing the tensioner and pick up tho due to their low cost.
    Is the tensioner easily accessible.
    Vex182 likes this.
  4. <tuffty/>
    21,957
    4,229
    ...and on my new engine
    As I said mate... its pulley off then cover off and you can get to the chain and the tensioner
    g60leigh likes this.
  5. g60leigh
    1,674
    207
    Was hoping tensioner was more accessible.
    Will leave well alone unless any signs of wear.
    Thank you
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    My tensioner was well worn (grooved by the chain), so i got the complete kit inc chain
  7. g60leigh
    1,674
    207
    At mileage was that on Dave?
  8. s3dave
    10,110
    736
    150k Leigh
  9. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Whats the tensioner like on the block i gave you dave? Thats 150k too.
  10. Westy
    Westy Well-Known Member
    17,443
    1,105
    I don't recall fitting a new seal on mine or a new bolt! Actually for that matter I don't remember much from my engine build weekend :beerchug:
    g60leigh and superkarl like this.
