Oil problem
kachnak Aug 1, 2010
  1. kachnak
    kachnak Active Member
    119
    45
    Hello, I found some oil near cap for motor oil put in. see picture please.
    I clean it but oil was there again. There is not much oil, only little slop.
    Anybody know where cen be problem? Thank you
  2. Matt82
    Matt82 Active Member
    2,365
    so its leaking around the oil filler cap?
    if so, thats not that uncommon, these cars are old, things wear. a new cap is only c.£7 from the dealer
    after that, check your breather system is in good condition. the breather should have been keeping the crank under vacuum, not blowing it out
  3. kachnak
    119
    45
    Thank you. I will try change oil cup.
    When motor was running and this cap was put off, there was not vacuum, but low blowing air out and some oil gobbet on my hand.
  4. Matt82
    2,365
    the cam below the cap would be throwing oil out, there still should be air being drawn out of the crank case via the breather hose going to the underside of the inlet manifold
  5. m4nj
    m4nj Member
    off topic im after the standard air box pipe that goes to the engine from the air box (the oem of the samco hose above) anyone have one? IM me please
    - Bal
  6. 666markyboy
    666markyboy Well-Known Member
    1,243
    62
    Someones nicked your car mate..... :search:
